Thu Nov 02, 2006 10:16 pm
I think the issue is the zone number should be "03" and not "3".
should be --> ZONE_VOLUME~03~49 FROM: MELODY
not ZONE_VOLUME~3~49 FROM: MELODY
Thu Nov 02, 2006 10:30 pm
Uploaded NEW Version
jackpod
Thu Nov 02, 2006 11:11 pm
Tracy, We have a plugin!
It was a combination of both the zero and the latest DLL. First i tried it with just the zero and it still went to full volume. I then downloaded the latest DLL and it works. I modified my mlmath statement to subtract and the volume goes up and down, both from the scene and the keypad. I also changed the math statement to jump 3 instead of one. It is time to go sit at the bar and then head to the theater. In the morning I will finish modifying the ML Scene so all zones work and give it a run thru.
It is not instantaneous but by no fault of the plugin, you can see from the log that the Nuvo is moving a lot of data and it takes a second to transmit back
Now I have a question for all of you (Tracy, Jim, David (and anyone else))
Which scene do you like better, the sliders or the buttons? which one do you want for the show?
About the only thing I have to work on besides alighning all the buttons is to find a way to make the source buttons go dark when power for that zone is off
Need Input!
Jack
Thu Nov 02, 2006 11:15 pm
jack:
Great to hear. Thanks for all of your help. I think that the push buttons would give you more control that the slider, but that is just me.
jackpod
Thu Nov 02, 2006 11:19 pm
Tracy, I am glad I was able to help. I agree with the push buttons because of the delay. A slider does not give as much control
Jim? Your thoughts
David? Your thoughts
Mario? Are you lurking?
Jack
jackpod
Thu Nov 02, 2006 11:27 pm
I was just doing some testing, we might have to put in an error trap if the button is clicked to fast. This was in the log and the zone became unresponsive. I want to play with increments as well, even 3 seems to be a pretty small step. Look for the *** this is where the error occured
event log
Processing Zone - 3 => Processing Command - #Z03PWRON,SRC5,GRP1,VOL-50
Processing Essentia Command
Processing Variables for Zone - 3
Sending command for ZONE_SOURCE - *Z03SRC5
Sending command for ZONE_SOURCE - *Z03SRC5 via COM: 1
Processing - zone_volume~03~-47 from Melody
CMD: ZONE_VOLUME~03~-47 FROM: MELODY
Processing Zone - 3 => Processing Command - #Z03PWRON,SRC5,GRP1,VOL-47
Sending command for ZONE_VOLUME - *Z03VOL47
Sending command for ZONE_VOLUME - *Z03VOL47 via COM: 1
Processing - zone_volume~03~-44 from Melody
CMD: ZONE_VOLUME~03~-44 FROM: MELODY
Processing Zone - 3 => Processing Command - #Z03PWRON,SRC5,GRP1,VOL-44
Sending command for ZONE_VOLUME - *Z03VOL44
Sending command for ZONE_VOLUME - *Z03VOL44 via COM: 1
Processing - zone_volume~03~-41 from Melody
CMD: ZONE_VOLUME~03~-41 FROM: MELODY
Processing Zone - 3 => Processing Command - #Z03PWRON,SRC5,GRP1,VOL-41
Sending command for ZONE_VOLUME - *Z03VOL41
Sending command for ZONE_VOLUME - *Z03VOL41 via COM: 1
Processing - zone_volume~03~-38 from Melody
CMD: ZONE_VOLUME~03~-38 FROM: MELODY
Processing Zone - 3 => Processing Command - #Z03PWRON,SRC5,GRP1,VOL-38
Sending command for ZONE_VOLUME - *Z03VOL38
Sending command for ZONE_VOLUME - *Z03VOL38 via COM: 1
Processing - zone_volume~03~-35 from Melody
CMD: ZONE_VOLUME~03~-35 FROM: MELODY
Processing Zone - 3 => Processing Command - #Z03PWRON,SRC5,GRP1,VOL-35
Sending command for ZONE_VOLUME - *Z03VOL35
Sending command for ZONE_VOLUME - *Z03VOL35 via COM: 1
***Here - too much data got passed***
Processing - zone_volume~03~-32MLServeCmd.Macro|MLMath|Add~mlnuvoessentia_zone_3_volume~-32~3 from Melody
CMD: ZONE_VOLUME~03~-32MLSERVECMD.MACRO|MLMATH|ADD~MLNUVOESSENTIA_ZONE_3_VOLUME~-32~3 FROM: MELODY
Error 13 (Type mismatch) @ Line 100 in procedure SendExternalCommand of modSharedCode
Command not syntax was incorrect
Sending command for ZONE_VOLUME - *Z03VOL-32MLSERVECMD.MACRO|MLMATH|ADD
Sending command for ZONE_VOLUME - *Z03VOL-32MLSERVECMD.MACRO|MLMATH|ADD via COM: 1
Processing - zone_volume~03~-32 from Melody
CMD: ZONE_VOLUME~03~-32 FROM: MELODY
Processing Return String - ##Z03PWROFF,SRC1,GRP1,VOL-62
Unable to process command -> ##Z03PWROFF,SRC1,GRP1,VOL-62
Sending command for ZONE_VOLUME - *Z03VOL32
Sending command for ZONE_VOLUME - *Z03VOL32 via COM: 1
Processing - zone_volume~03~-29 from Melody
CMD: ZONE_VOLUME~03~-29 FROM: MELODY
Processing Zone - 3 => Processing Command - #Z03PWROFF,SRC1,GRP1,VOL-62
Sending command for ZONE_VOLUME - *Z03VOL29
Sending command for ZONE_VOLUME - *Z03VOL29 via COM: 1
Buffer partially filled - Waiting for additional data
Processing Zone - 3 => Processing Command - #Z03PWRON,SRC1,GRP1,VOL-62
Required turning the zone off and back on. If the increment step is a little larger, maybe a delay could be placed or a string length error trap
I will investigate in the morning
Jack
Thu Nov 02, 2006 11:36 pm
That looks like a MLS issue. Some how it passed that Macro string to the plugin by mistake. Better get Smooth or DaveP to look at that. I may need to decrease the amount of time I am waiting while processing the command. I will compile another version in a minute.
Thu Nov 02, 2006 11:57 pm
Posted a new version. This version shortens the time between processing commands.
jackpod
Fri Nov 03, 2006 7:48 am
Good Morning!
I will download the latest Dll and be testing as I finish populating the ml scene
Jack
I will send Dave P an emai lasking him to look at that error. Easily reproduced by the way, have done it 3 times by clicking very rapidly
jackpod
Fri Nov 03, 2006 8:46 am
Tracy, the latest has good response, still get an occasional error, not sure as to why yet, but I was hitting the button rapidly
Processing Zone - 2 => Processing Command - #Z02PWRON,SRC1,GRP1,VOL-57
Processing Variables for Zone - 2
Sending command for ZONE_ON - *Z02ON
Sending command for ZONE_VOLUME - *Z02VOL52
Processing Zone - 2 => Processing Command - #Z02PWRON,SRC1,GRP1,VOL-52
Sending command for ZONE_VOLUME - *Z02VOL47
Processing Zone - 2 => Processing Command - #Z02PWRON,SRC1,GRP1,VOL-47
Sending command for ZONE_VOLUME - *Z02VOL42
Processing Zone - 2 => Processing Command - #Z02PWRON,SRC1,GRP1,VOL-42
Sending command for ZONE_VOLUME - *Z02VOL-37MLSERVECMD.MACRO|MLMATH|ADD
Unable to process command -> ##Z02PWROFF,SRC1,GRP1,VOL-62
Sending command for ZONE_VOLUME - *Z02VOL37
Sending command for ZONE_VOLUME - *Z02VOL32
Processing Zone - 2 => Processing Command - #Z02PWROFF,SRC1,GRP1,VOL-62
Sending command for ZONE_VOLUME - *Z02VOL57
I'll play some more and see if i can put my finger on it
Jack
jackpod
Fri Nov 03, 2006 9:04 am
Ok I just had all 6 zones working, different inputs, different volumes, some turned on from ml some turned on from keypads.
It all looks good...
Now, purely cosmetic but, on the source buttons. How can i make the selected source button go dark when the power is off since we are using the off state to show the source is selected. ?
AutomatedOutlet
Fri Nov 03, 2006 9:52 am
ok tracy,
Everything works with the latest loads except for the balance and I think that it is just a cosmetic issue. When you try to put the balance to center it sends the proper command and the concerto reacts properl;y, however the display pops back to the previous setting in this case 1 click to the right.
Sending command for ZONE_BALANCE_RIGHT - *Z01BALR1
Processing Zone - 1 => Processing Command - #Z01BASS+00,TREB+00,BALR+1,G0,MAXVOL-30,INIVOL-55
Processing Variables for Zone - 1
Sending command for ZONE_BALANCE_CENTER - *Z01BALC
Processing Zone - 1 => Processing Command - #Z01BASS+00,TREB+00,BALC,G0,MAXVOL-30,INIVOL-55
otherwise everything looks great!
Good Job
Looking forward to seeing the MLS file Jack.
BTW I think the butons will be fine, I just think that cosmeticly it looks spiffy and techy with the faders, but if they cause delays then I would much prefer the buttons.
Jim Houston
Martin Custer
Authorized Cinemar Distributor
www.AutomatedOutlet.com
jackpod
Fri Nov 03, 2006 10:33 am
Ok here you go...
I am sure there will be additional tweaks.
#1 will be to find a way to grey-out the source buttons on zones that are off, easier said than done. In order for the source buttons to toggle I had to use the off state as an on indication. I will see what I can do
#2 will be to take the bar graph to zero on zone off power, but here i have mixed feelings... it depends on how you have the keypads configured for volume restore. If you have it set to reset to minimal volume on power on, fine when you turn on the zone the volume resets to 21 on the bar graph. If you have it set to last set volume, you could be in for a surprise. I have some keypads set for last volume and some set for reset to minimal, so maybe the bar graph should be left as is.
#3 Tone Controls. On the Essentia you can set bass and treble via the keypad, I have mine all set for each of the rooms and have never had a need to adjust them. Possible idea (if I am clever enough to figure it out) would be to use the new slide-out menu of ML and overlays (something I haven't done before, but this beta testing taught me a lot), the slide-out when then contain the tone controls for that zone
#4 the buttons on the top are particular to my setup, they take you to the XM Radio scene, Music Lobby scene and the "whole House Audio" button takes you to my main scene, so you might want to take those off if you decide to use this scene as a demo (which by the way you are more than welcome to use it or any part)
jackpod
Fri Nov 03, 2006 10:35 am
And here is the MLS
Nuvo.mls
(405.02 KiB) Downloaded 50 times
AutomatedOutlet
Fri Nov 03, 2006 10:44 am
Thanks Jack,
I look forward the downloading and playing with it. The graphic is looking good. I will be using it as demo here at the office with the Concerto and modifying it for use with the Simplese for the EHX show in Long Beach week after next.
Jim Houston
Martin Custer
Return to “MLNuvo”
