jsprop
Sun Feb 25, 2007 11:05 pm
Tracy,
It looks like the the MLMarantzSR_Digital_Singal_Format variable is not changing. It has not moved from PCM
John
John
Sun Feb 25, 2007 11:43 pm
It should be returning a command like @SIG:_ . Can you tell me what command it is returing when you change formats? You should see the device response if the logging is turned on.
Is everything else working ok?
jsprop
Sun Feb 25, 2007 11:52 pm
Thats the only one that I see not working. All the other one that I have played with have worked well.
I'll take a look.
John
Sun Feb 25, 2007 11:54 pm
jsprop
Mon Feb 26, 2007 12:08 am
Maybe I don't under stand the variable Should this variable change when I send a deferent type of signal to the receiver?
I have the receiver set for auto so I don't make the change myself.
John
Mon Feb 26, 2007 12:14 am
I would expect the receiver to send a device response when the source type changes. If it does not, I will not be able to update that variable
jsprop
Mon Feb 26, 2007 12:18 am
When I changed from mp3's to dvd to cable the display changed but there is nothing on the log.
John
Mon Feb 26, 2007 12:35 am
It must not be reporting that variable.
try running mlservecmd.MLMarantzSR|Auto_FeedBack_Status_7
this should tell the device to send all responses that it has available. If this does not cause the device to respond, we are probably of luck
You can also try pressing the update button on the plugin after you see the display change.
jsprop
Mon Feb 26, 2007 12:48 am
When I did the update with the plugin it worked.
John
Mon Feb 26, 2007 10:13 am
It sounds like the receiver is not sending the response when format changes. Did changing the Feedback status to 7 help anything?
jsprop
Mon Feb 26, 2007 10:32 am
It didn’t make any difference. I don’t use the FM stuff, but the number of the frequency is at 655.5. I took another look at all the variable and didn’t see anything that didn’t make since. The mute and volume are working.
John
jsprop
Tue Feb 27, 2007 9:03 am
Is this something your side or is something up on my side?
John
jsprop
Thu Mar 01, 2007 5:08 pm
Tracy,
Whats the word on this?
John
jsprop
Mon Mar 05, 2007 11:37 pm
Tracy,
Are you out there?
John
Tue Mar 06, 2007 2:09 am
Sorry John, I am out of town on a project. I wont be back until Friday. Can you turn on logging and change the frequency and see what kind of response you get?
thanks
tracy
Return to “MLMarantz”
