pacman
Audio Remote to searve all sources
Sun Nov 18, 2007 3:33 pm
Hi
I am trying to create a one screen audio remote that will based on choosing a source it will update the remote buttons (Controllable buttons for source), cover art and music info variables. I have dabbled into the cycle states plug in but I believe that the MLMenu is the way to go!!
Basically I will lead from a 6 source page that will always lead to the same remote and make all the buttons and variable correspond to the source (Music Lobby 1, Music Lobby 2, Music Lobby 3, Ipod, DMC (Hal Digital Music Center) etc
I think that I will have to set some variables and a goto level cmd for the menu to make this work. I am having trouble using the goto level cmd anyone have an example that does work, I have looked at the wiki and still can't make it work
James
Sun Nov 18, 2007 8:19 pm
James:
If you send me what you have done to date (mls and mdb), I will be more than happy to try and help. I will send you the code syntax when I get back home.
Sun Nov 18, 2007 11:26 pm
The command appears to have error in it. I compiled a new version that uses the following commands. It is version 3.169. Should be available tonight or tomorrow.
the goto level command is:
MLMenu|Goto~Menu#~Level~ButtonID
where:
Menu #- the menu number
Level - Level you are request (where first level = 0)
ButtonID - the button id of the button you press to get to this level
Use the command
Create_Top_Menu~Menu#
to create the top level menu
pacman
Mon Nov 19, 2007 3:12 am
Hi Tracy
Thanks for the offer to help, I will try the new version when it comes out. I think I have something that going to work but I still think ML Menu is the way to go.
Great job this should make editing a lot faster and easier.
Thanks again
James Paquin
Mon Nov 19, 2007 3:16 am
Let me know if there anything that I can add to make it any easier.
