snx
Jandy Driver - Autelis Support
Sat May 09, 2015 5:13 pm
Does anyone know if the existing driver works with the Autelis Pool Controller? I see that the driver supports communication via a global cache unit and a port can be specified.
http://www.autelis.com/pool-control-for ... odiac.html
http://www.autelis.com/wiki/index.php?t ... t_Firmware
Using the available serial firmware, it functions just like the Jandy serial interface but over ip. I have one installed and so far it seems a bit faster and less flaky than the Jandy interface.
Re: Jandy Driver - Autelis Support
Sat May 09, 2015 8:26 pm
The commands shown on that wiki page are identical to the command set in the Jandy driver. It should work. If it doesn't i can make it work.
snx
Sun May 10, 2015 7:44 pm
The driver accepted the custom port number but shows the following error continuously:
5/10/2015 7:35:39 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:35:44 PM SendCommand TX: 1|#OPMODE?
5/10/2015 7:35:44 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:35:49 PM SendCommand TX: 1|#VBAT?
5/10/2015 7:35:49 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:35:55 PM SendCommand TX: 1|#UNITS?
5/10/2015 7:35:55 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:36:00 PM SendCommand TX: 1|#PUMPLO?
5/10/2015 7:36:00 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:36:05 PM SendCommand TX: 1|#CLEANR?
5/10/2015 7:36:05 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:36:10 PM SendCommand TX: 1|#WFAL?
5/10/2015 7:36:10 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:36:16 PM SendCommand TX: 1|#SPA?
5/10/2015 7:36:16 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:36:21 PM SendCommand TX: 1|#POOLHT?
5/10/2015 7:36:21 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:36:26 PM SendCommand TX: 1|#SPAHT?
5/10/2015 7:36:26 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:36:32 PM SendCommand TX: 1|#SOLHT?
5/10/2015 7:36:32 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:36:37 PM SendCommand TX: 1|#SPASP?
5/10/2015 7:36:37 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:36:42 PM SendCommand TX: 1|#SPATMP?
5/10/2015 7:36:42 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:36:47 PM SendCommand TX: 1|#AIRTMP?
5/10/2015 7:36:47 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:36:53 PM SendCommand TX: 1|#SOLTMP?
5/10/2015 7:36:53 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:36:58 PM SendCommand TX: 1|#AUX1?
5/10/2015 7:36:58 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:37:03 PM SendCommand TX: 1|#AUX2?
5/10/2015 7:37:03 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:37:08 PM SendCommand TX: 1|#AUX3?
5/10/2015 7:37:08 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:37:14 PM SendCommand TX: 1|#AUX4?
5/10/2015 7:37:14 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:37:19 PM SendCommand TX: 1|#AUX5?
5/10/2015 7:37:19 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:37:24 PM SendCommand TX: 1|#AUX6?
5/10/2015 7:37:24 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
5/10/2015 7:37:29 PM SendCommand TX: 1|#AUX7?
5/10/2015 7:37:29 PM OpenNetwork Error at OpenNetwork at line #556 - Invalid key
Mon May 11, 2015 11:56 am
How is that controller defined in Family Manager? There is something in the address field. I'll need to see how it was defined.
snx
Mon May 11, 2015 1:09 pm
Just by ip address.
Mon May 11, 2015 2:13 pm
Thanks, when I wrote the Jandy driver I was never expecting to talk to anything but a real serial port or a Global Cache device. So port 6000 was confusing it. I just modified the driver and it will accept port 6000 now. Give it a try. If you still have issues with it I will have to remote into your MLServer PC to properly debug the issue.
snx
Mon May 11, 2015 4:27 pm
Same errors unfortunately. Delete & recreated the entry in Family manager a couple of times just to be sure. Telnet from the server to the controller works.
PM sent with login info.
Fri May 29, 2015 7:22 pm
Those devices should all talk with http get. I'm getting the one for pentair because it gives me access to everything. It should be the same format or close.
Fri May 29, 2015 8:21 pm
The driver has been updated to support the port this device uses.
Users browsing this forum: No registered users and 3 guests
