chrisan
UPB Error at LightOnToLevel at Line #680 - SOLVED
Fri Jan 20, 2017 5:20 pm
When you import your UPB system map into myServer a couple of critical values need to be added:
Network ID
Network Password
In myServer click on Device Drivers
Then double click the line that contains your UPB driver
A dialogue box will appear where you can input these parameters.
To find your Network ID and password enter UpStart and double click on one of your devices.
These parameters can be found under the ID tab.
Re: UPB Error at LightOnToLevel at Line #680 - SOLVED
Sat Jan 21, 2017 10:39 am
Added that to the UPB installation documentation to make it clear.
thanx!
Return to “myServer Apps”
