VMWare Server does the job
Tue May 02, 2006 1:47 am
I've been running on VMWare Server for a couple of months now.
First I ran HS2 in a VM on the same machine that used to run HS1.7. In theory, this was going to give me a chance to roll back if necessary, but I ended up never going back to HS1.7.
After by MLServer system crashed (MB issue... I'd overheated it a bit I think :roll:), I pushed it over to VMWare as well. I'd tested it briefly before so I knew it could work, but I hadn't found a good solution for all the attached USB and serial devices.
I tried a PCI / serial card, but VMWare wouldn't map all eight ports through. I tried a Comtrol terminal server but it worked poorly. I went to a 4-port-USB-to-serial adaptor and it worked pretty well. Then I added a couple more GIG of memory, taking the box from 1G to 3G.
BANG! It all worked well.
I went back to the Comtrol IP-to-Serial... and it works great!
So... now I can move the virtual machine to any system I want and I only need to move the USB-based devices that are attached and map them through to the VM (XMPCR is the main one).
I've got a SlinkE, 2 CX777ESs, and the Rotel RSP-1066 preamp all through serial.
Interestingly, I'm able to move the HS2 serial devices to the box as well and map those ports to the HS VM while other ports are mapped to the MLS VM.
I'm VERY pleased with the setup.
The next trick is getting my web server back up on another VM. I'm LAME at Apache / PERL / PHP / MySQL type of stuff... and my developers at the office don't want to deal with my Windows WAMPP environment, so they may push me to a RedHat VM so they can support XAMPP... which is fine with me as long as I can get my OLD web server up as well as a new PHP version.
'Nuff babbling.
VMware. Love it.
8)
madmax
Thu May 04, 2006 1:46 pm
What type of CPU are you using? I was considering this type of setup at one point, but was concerned about the hardware limitations. Do you use multiple USB soundcards on this setup? How about voice recognition on Homeseer?
Thu May 04, 2006 1:55 pm
It's running on a 2.8GHz P4.
I'm only running the one audio on the MB now.
I only briefly tested HSVR but I'd expect it to work if the client is on another system.
PeterM1
Thu May 04, 2006 3:24 pm
gregoryx wrote:It's running on a 2.8GHz P4.
Any luck passing Delta 410 outputs to the local VMs? My only problem (with VM server beta now, Workstation before) is the limitation of one audio device per VM. Delta splits up the pairs into separate devices so I can't have a JRMC VM that controls all 4 pairs. Plus it chops off the Delta device names but that's more of a nuisance than anything else.
Thu May 04, 2006 4:47 pm
I have JRMC native on the host now. I'm considering a USB based audio device if I go VM for JRMC.
Return to “What's Your System Configuration”
