ha_kiwi
New Member
New Member
RS232 with Touchscreens
Sun May 12, 2013 8:30 am
I have 2 PC's with Quad Videocards and Quad RS232 Cards which I intend to use with 4 touchscreens on each. I have 2 different types of quad RS232 cards. If I use standard RS232 Cables then both cards work fine with the Touchscreens but if I use Cat 5E Cables with DB9-RJ45 adapters 1 quad card works and 1 doesn't. Any ideas please as I cannot find another of the cards that work. Your help please I'm stuck
Re: RS232 with Touchscreens
Mon May 13, 2013 12:19 pm
My guess would be to check the Cat 5 cable and look for a bad connection. The card should not care what is connected to it. So it must be a cable malfunction.
Return to “Home Automation”
