guigraphix linking
Tue Jan 08, 2008 10:23 pm
Like we have in tvlobby, and internal link in the application to put the channel and its graphic together in a variable that can be used on screen dwesign.
For example, on my main home sccreen i can view the currently chosen media for a zone and view its now playing info. For XM, i'd like to show the xmchannel graphic from the xmlogos guigraphic library and have that dynamically change when the channels change.
Right now i just display a boring old channel number in text format.
Sat Jan 19, 2008 10:27 am
Any response? :? Personally I think it's a good idea, and is congruent with the other media plugin (TV lobby) feature set. Heck it even makes the cost of the XM guigraphix library make sense....
Sat Jan 19, 2008 12:14 pm
ChrisB, XM is not on the immediate radar right now. We have a solution we have done some development on already, but it's not ready yet.
Sat Jan 19, 2008 6:35 pm
thank you....obviously hopeful it can move forward. it's a solid plug-in already, just a strong extension opportunity.
Thu May 29, 2008 2:12 pm
Chris,
You could pull off what you are trying to do using the internal tools of MLServer/MainLobby.
It would require that you use MLCycleStates
I would create a table that lines up with XM Channel Logos and Numbers.
So:
1 .. 3 would be blank
4 is in the Data Column
0017_xm004 is the label
Do this for each station.
Then Create an Automation rule that sends:
MLCycleStates|Set~XMChannels~{{xmcurrentchannelnumber}}
Where XMChannels is the name of the Table in MLCycleStates
We use the xmcurrentchannelnumber to jump to the appropriate row of the table.
You don't need to prefix the clientname in the XMChannels table since this is not client dependent but instead source dependent.
This will create a variable called: XMChannels_label = 0017_xm004 assuming you are on channel 4.
Now from your Scene Startup where the graphic exists - enter the following:
MLCmd|{{clientname}}~setProperty|graphic~stage~xmGraphic~{{xmchannels_label}}
Next for the XMChannel Graphic, put xmGraphic as your alias so the command above will know which graphic to change. This assumes the graphic is on the stage layer and not on an FX layer too.
You'll need to make your rule send this command as well to all clients.
Hope that helps. The table only needs to be built once and can be shared with others who might be interested.
Thu May 29, 2008 10:30 pm
Mario ~
Thank you for the inspiration. Good project for the weekend.....and yes, I will share when done.
rondepping
Fri May 30, 2008 5:23 pm
Mario,
Any chance of an update to the XM Logo lib? There have been some new channels, some of the existing channels have changed names, etc. since the lib was updated last.
Just curious, because if I do set up this xmlogo cyclestates table it would be nice if the logos matched the current xm stations. :)
Fri May 30, 2008 5:30 pm
Can you give me a heads of the ones that have changed?
rondepping
Fri May 30, 2008 7:27 pm
Quick list, not comprehensive.
Channel Name Status 2 XMX New 4 40s Changed logo 5 50s " 6 60s " 7 70s " 8 80s " 9 90s " 10 America " 11 Nashville " 12 X country " 13 Willies Place Changed name & logo 14 Bluegrass Junction Changed logo 15 The Village " 16 Highway 16 " 17 Strait Country Changed name & logo
New channels 231 - 239 , 241, 242, 244,245, 247, 256
Just to name a few. I'll make a complete list this weekend and post. Until I started looking close I didn't realize how much had changed. It looks like they updated most of the logos.
For now here is a link to the latest channel listing with logos in a pdf.
XM Channel listing
rondepping
Fri May 30, 2008 9:22 pm
OK Here are the diff's as I see them. Some of the logo changes are minor, others are not. Plus a lot of new channels, and a bunch of changed names.
Mon Jun 02, 2008 7:57 am
My how things have changed. ;)
Mon Jun 02, 2008 12:14 pm
rondepping wrote:Mario,
Ron and All,
Login and redownload the XM LOGO Library. It now contains all the latest images and new stations.
rondepping
Mon Jun 02, 2008 4:25 pm
Mario,
You Da Man! =D> \:D/
Thank you for the great customer Service!
Mon Jun 09, 2008 8:41 pm
i'll admit to being tired i will not admit to being lazy....
you can call me either
did anyone do the command map cycle states xm logo setup that's willing to share?
Tue Jun 10, 2008 12:25 am
I did this way back and will pull the files together for you this weekend.
Return to “XMLobby Feature Requests”
