jglitch
xm feature requests
Fri May 28, 2004 1:25 pm
XM feeatures I'd like to see added:
Sleep Timer
Wake to Music Alarm
On/Off for each zone thru mrdia center
A mini player overlay/OSD w-tilte/station/on-ff/mute/vol for all scenes
After switching to favorite artist thru pop-up, when song is over, xmlobby returns you to your "original" channel.
Probably can do this thru hs and mainlobby --- ---- blankscreen/xmlobby screen(for song info) based on motion sensor ... room status ... wen your doing the whole house audio thing
Love it as is tho
Fri May 28, 2004 3:03 pm
The sleep timer can be done now via HomeSeer integration. You put your schedule in HS, and HS tells XM when to turn on / off. Same with wake timer.
Ultimately, you will be able to listen to your XM via MediaPlayer (from anywhere!) Probably (but not verified) from MC too.
If I remember right, the controls for XM Upgrade are usable outside the user interface so you could build this remote now (especially with 2.70b Mainlobby Overlay Scene controls).
kimknapp
Integrated into MusicLobby
Tue Jun 08, 2004 4:43 pm
Would love to see XM integrated into MusicLobby.
Tue Jun 08, 2004 8:28 pm
Second that last one. I'm going to make my Music Lobby and XM Lobby look nearly identical for switching between them so I can keep consistent with the "play music" idea... regardless of what that music source is. Gotta keep in the heads of the users... not the geeks.
Tue Jun 08, 2004 11:12 pm
Another request: if that little thing below the "Main" is the signal strength, right? I'd like the ability to specify which signal strength to watch. My signal on the ground is great - no reason to bother with the satellite, right?
How about a future option to look for the album on more than one purchasing source. A used source like Second Spin would be cool...
Next: any ideas where I might find the cover art graphic for the currently playing item? I'm thinking that it'd be preferable not to have the list of stations on the right all the time and it seems to me that the best way to deal with this is to dump the whole XMLobby.swf in favor of using variables. Ideas?
Uh... is it obvious that I just got the XM last night and am playing with this for the first time? Pretty cool stuff. Thanks, Dan!
:D
jglitch
Tue Jun 08, 2004 11:18 pm
I listen to the same XM station 85% of the time, really dont need the channel list either, so Ive already built my own XM Scene with variables Dan provided (going to do the same for musiclobby) and have already requested the info to change channels (favs)and have cover art on "My Scene"
Jeff
To think someday I'll be able to answer ML questions, not just ask them!
Sun Jul 18, 2004 4:52 pm
Jeff, did you get your cover art working?
gfabiii
XMLobby Visualization
Thu Jul 22, 2004 10:21 pm
If there is not an Album Cover to down load from the NET could a
visualization play in place of the Album Cover.
Return to “XMLobby Feature Requests”
