kgudge
Sun Jun 15, 2008 8:04 pm
have sports!
have movies!
have actors!
have actors films!
how do you guys display long named channels like disney cinemagic paramount comedy or cartoon network?
i cant be the first to have an issue with 10 lowercase digits or seven uppercase digits for the channel name?
kgudge
Sun Jun 15, 2008 8:27 pm
I guess you guys must be using the 0015 library?
Fonceur
Sun Jun 15, 2008 10:00 pm
kgudge wrote:have sports!
have movies!
have actors!
have actors films!
Good!
Well, normally it should only be the channel call sign (i.e. MHD) while the actual name can be much longer (i.e. Movie Network High Definition Feed). The problem with the Radio Times data is that they don't include both... ;)
kgudge
Mon Jun 16, 2008 6:55 am
I really need either plugin access to add my own icons or the channel map.
Channels like Sky Sports 1, 2 and 3 all appear as "Sky Sport".
I tried sniffing the grabber to see where it pulls the channel_ids file from, set a hosts entry to localhost for that URL but can't server my own channel_ids file to map tvlobby friendly names. It just breaks the grabber. I hoped it might default back to the local version on error but that doesn't work either.
So close, yet so far.....
Fonceur
Mon Jun 16, 2008 9:48 am
kgudge wrote:I really need either plugin access to add my own icons or the channel map.
I haven't abandoned the idea of the channel map, I am simply stuck in the implementation. Expect some more beta versions with debugging enabled... ;)
As for adding your own icons, I will look into that too. I like the idea, though I'm not sure what kind of constraints exist on that part.
Fonceur
Mon Jun 16, 2008 10:29 am
OK, this version should be a lot more verbose about what is going on with the channel map. If you could try to take a screenshot where (if) it crashes, and maybe write down the rest as it goes...
The parts of interest are:
- Read X lines (followed by a 5 seconds pause)
- Skipping: #... (the commented lines in the channel map)
- Adding: ... (the proper lines)
- 0 - Channel = (actual channel)
- 0 - Name = (actual channel's name)
- Found Y entries
- Redim done
And then if it actually worked or crashed... ;)
kgudge
Mon Jun 16, 2008 10:35 am
Good to hear, channel_ids was only a suggestion. I'm happy to create any file.....as long as it works.
kgudge
Mon Jun 16, 2008 10:39 am
would a simpler file map life easier?
Could use a modified conf file like the one attached.
replace channel with local channel name, delimeter of your choice....
Will try .43 now!
tv_grab_uk_rt.zip
(433 Bytes) Downloaded 32 times
Fonceur
Mon Jun 16, 2008 10:53 am
I think the last line of the file might have been an issue, so if it was, here is an updated version to skip the blank lines... ;)
kgudge
Mon Jun 16, 2008 11:32 am
Better, just pulled 5 channels.
DB is populating. Got several walkchildren #13 errors but no crashes.
all channels shows as ch22, which none of them are....
That was with generic channel_ids unmodified. Going to re-try with just the 5 channels. Correct names and channel numbers.
Fonceur
Mon Jun 16, 2008 11:38 am
kgudge wrote:would a simpler file map life easier?
I like the KISS (Keep It Simple Stupid) approach, so having it work with the original channel_ids or a renumbered one is better.
Regarding the errors, are you seeing any of the text mentioned in my post? I am not quite sure why it is using channel 22, as it should be using the incremental approach and by-passing the channel map logic for the database update...
kgudge
Mon Jun 16, 2008 11:46 am
Fonceur,
Wehn I look in the database. Channel names and channels aren't right.
This time all the channels are = to 1.
The remapped names are included either.
This is all I see in the log entry. It seems to read my channel id file since is has five set to 134. However this isn't being written out to the db.
walkchildren errors can be seen.
Fonceur
Mon Jun 16, 2008 12:13 pm
kgudge wrote:Wehn I look in the database. Channel names and channels aren't right.
Yes, it turns out I wasn't actually by-passing that step in the database creation. This version will revert to old behaviour.
Indeed, the reading part seems fine! Now I just need to figure out that type mismatch...
Fonceur
Mon Jun 16, 2008 12:24 pm
OK, I found the type mismatch, nothing a Str$() can't fix... ;) So try this one.
kgudge
Mon Jun 16, 2008 12:46 pm
no difference....apart from the logging. .46 build
One minor update, I'm now seeing the channelname showing when I click on a channel in the centre section.....not sure when this strated showing up.
So more progress!
See attached
Return to “TVLobby Questions & Answers”
