hikarion
Hikarion Screen Shots
Mon Aug 08, 2005 4:38 pm
Here are a few screens of the new interface i did that is almost complete.
I custom made over 400 flash buttons and images, which are all © me :)
Ripper
Mon Aug 08, 2005 5:02 pm
Wow that looks great...do you happen to have any links for Flash button tutorials for instance to change from imageup.png to imagedown.png, I have found alot of tutorials that show mouseover image buttons but nothing for a click event...I'm sure this is relatively easy but I havent seen an accurate tutorial to do this in either Flash or Fireworks...any help would be appreciated.
Once again great work!
AccessHA
Mon Aug 08, 2005 5:25 pm
hikarion,
Thanks for posting your work, beautiful job.
Hell-bent on automating everything! I’m too lazy to do anything else.
www.accessHA.com
Access Home Automation
The ultimate Insteon resource on the web.
davevans
Mon Aug 08, 2005 5:55 pm
WOW amazing screens hikarion! Any chance you could post how you did your zone selection/monitor screen. That's really slick!
Dave
indecision
Mon Aug 08, 2005 9:29 pm
That looks fantastic. One of the best I have ever seen. Any chance you want to share or sell any of your work?
Incredible!
Tue Aug 09, 2005 2:03 am
Oh, man... beautiful stuff. :shock:
What are you going to share? :D
mediastorm
Nice
Tue Aug 09, 2005 4:50 pm
Very, very, very nice stuff. Excellent job!
Are you planning on selling your collection or do you have other ideas in mind?
Nexus
Tue Aug 09, 2005 5:33 pm
For the adventuress type… this will get you started:
http://www.good-tutorials.com/track/9214
Tue Aug 09, 2005 6:17 pm
hikarion, I'm very interested in how you're doing the zone controls also. Speak up! :P
hikarion
Tue Aug 09, 2005 11:41 pm
Hey, been pretty busy - as far as the zone page are you talking about in general how i handle zone/control switching of the UI or the images on the page, if its the first then you'll need to give me some time to write something up.
Basically i use almost no ML commands directly in MainLobby i'm using A LOT of command maps.
The way that page works for display you guys can figure out easy just a lot of variable tracking and setting and batch files to copy images
Wed Aug 10, 2005 1:36 am
It's the commands of those command maps I'm interested in. :P
How about on export of the command maps? :D
Ripper
Wed Aug 10, 2005 2:52 am
Nexus wrote:For the adventuress type… this will get you started:
Excellent tutorial.., I have included a zip with 2 example .psd to make a button like the one I have attached..instead of the circle I made a rounded rectangle.
example.zip
(169 KiB) Downloaded 89 times
sfreiman
Thu Aug 11, 2005 9:04 pm
Saaaaahhhhweeeet!
jss
Fri Aug 12, 2005 9:28 am
Didn't know you could customize the look of DVD lobby like that. I assume you wrote your own dvd lobby interface in flash. Is it documented how to do this?
-JSS
Fri Aug 12, 2005 1:06 pm
Pretty simple to strip DVD Lobby down - more complex to fancy it up - let alone how well hikarion has done it!
First, create a button on the DVD Lobby scene and label it "setup" and set the "ML Command Line" (in the upper right corner) to MLcmd: DVDLobby and var:DLsetupMode. Technically, you don't have to do this, but you'll be editing text files and/or pulling hair out and/or posting and getting mad at me if you don't.
Next, go to Setup in DVD lobby and hit "false" on "Show Buttons" and "Y" to "Hide Remote" and "X" to "Title Text Size" then hit "save".
From there, you'll want to go through the DVD Lobby and see the various MLCmd and var: parameters to perform all the functions that were there by default. :wink:
Return to “User Gallery - Screenshots”
