sonypoolplr
Loosing Connection?
Mon Feb 23, 2009 7:31 pm
For the last two days I have had to push the disconnect button multiple times and then the connect button multiple times to get the plugin/global cache unit to work. Does anyone know why this is happening? If this is the way this combination is supposed to work, I am not very happy with it. All of the other Cinemar plugins work well but this one is a real pain.
jjjukebox
Mon Feb 23, 2009 10:31 pm
Depending on if You get an error message back or not but I found that some hex codes either hung up the GC response back or caused it to timeout.
I have had to be very careful on getting correct hex codes when learning them.
Turn on the log and monitor which commands dont get a "RCVD" response or cause an error and try relearning it.
Had this problem for years and finally think I got things running with out errors.
Just a suggestion.
J.J. Jukebox
rileydog
Wed Mar 04, 2009 12:28 am
I have had the same problem recently - when I was testing commands, I would have to restart ML because GC would cease up. I would throw commands thinking something else was wrong and when I restarted ML all was well.
My trick was re-learning some commands in GC - for example, I had a problem where when I sent a volume down to a HK receiver - everything went haywire. Then, I re-learned the command and it worked fine after a restart.
Return to “Global Cache”
