Analog temp to variable
Mon Oct 20, 2008 10:51 pm
I need to read the temp from my hot tub and control it from there. The control is easy, however I need to read the temp. I understand the probes work like pots, so I should be able to read the voltage change on the m1g input and make a rule to change a variable to reflect a temperature. Can I send that variable (or read it) from Cinemar, and treat it as a number to make rules in cinemar?
ps- the elk temp sensors will not work, I have to use the type designed to drill into the pipe.
Mario or Dave....or anyone... can I read Elk M1G's variables in cinemar?
[/img]
Return to “Elk Products”
