TIP: Sending an MLServeCmd from the Elk to MLServer
Wed Mar 01, 2006 8:48 pm
Open the ElkRP Software (not the Elk plugin) and add some items to the Texts section.
Such as:
MLServeCmd.SetVariable|lightstatus~on^M
MLServeCmd.SetVariable|lightstatus~off^M
The ^M should be put at the end of each MLServeCmd to send a carriage return.
Then go into the Rules section of the ELKRP software and set up some rules.
IE:
WHENEVER outbound(Zn 15)BECOMES NOT SECURE
THEN SEND THE FOLLOWING TEXT: "MLServeCmd.SetVariable|lightstatus~on^M" THROUGH PORT 0
Cameras007
Wed Mar 01, 2006 11:55 pm
Mario-
I am now able to switch ML scenes when an input changes from the ELK M1.
However I had to REMOVE the ^M in order for ML to switch scenes.
It has a note in the ELK RP Software that says "Recieved Text Must End In A Carriage Return", not text that is being sent out. Thank you for your help tonight David P. and Mario, It's nearly 12:00am I have burning ML-EYES and have to get to some sleep!
:shock:
"I do not fear computers, I fear the lack of them." ISAAC ASIMOV
majeds
Sun Jun 15, 2008 6:43 am
Is this valid only if the MLServer is connected to ELK through serial port ?
I have my ELK connected to my network using the Ethernet module and I tried the command with no success.
Sun Jun 15, 2008 12:17 pm
Should work either way. Post the Elk event log showing the commands being sent.
majeds
Sun Jun 15, 2008 1:33 pm
Your confirmation encourage me to re-test and I found myself leaving the ELKRP connected to the security main unit. I disconnected ELKRP and now everything is working as expected.
BTW, that's amazing me on how the command is catched by MLServer without specifying the MLServer IP. Good job and thanks for your prompt response.
Return to “Elk Products”
