digitaltrader
Error after plugin Install
Sat Sep 30, 2006 1:59 am
I get the following error after the plugin install:
9/30/2006 12:53:59 AM Initialization Server MLServer version 3.0.97
9/30/2006 12:53:59 AM Initialization Server Running on THEATER
9/30/2006 12:53:59 AM Server License Thank you for evaluating MLServer 3 for MainLobby!
This is a fully functional version of MLServer 3 for MainLobby for evaluation use only.
This evaluation version expires in 29 days.
9/30/2006 12:53:59 AM Server License Server is licensed for 0 clients and 5 clients have been activated
9/30/2006 12:54:06 AM Error MDIForm_Load Plug-In VideoStorm Error# 429 - ActiveX component can't create object raised by MDIForm_Load Plug-In VideoStorm
9/30/2006 12:54:06 AM Error MDIForm_Load Plug-In VideoStorm Error# 91 - Object variable or With block variable not set raised by MDIForm_Load Plug-In VideoStorm
9/30/2006 12:54:06 AM Error MDIForm_Load Plug-In VideoStorm Error# 9 - Subscript out of range raised by MDIForm_Load Plug-In VideoStorm
9/30/2006 12:54:06 AM Plugin Server MLTimer subscribes to startup notification
9/30/2006 12:54:15 AM Error MLServer function cmdSettings_Click attempting to call SETTINGS function in plugin VideoStorm Error# 91 - Object variable or With block variable not set raised by MLServer function cmdSettings_Click attempting to call SETTINGS function in plugin VideoStorm
digitaltrader
Wed Oct 04, 2006 12:58 am
Any ideas of what may be needed. How does the plugin know which com port to look for? The settings option in MLServer brings no menu up. What can I do to resolve this?
digitaltrader
Wed Oct 04, 2006 1:35 am
I used the provided install .exe file but it continues to install itself in its own directory called mlmatrixswitcher despite me pointing just to the c:\program files\mlserver\plugins directory. It will then install in a subdirectory in the plugins folder called mlmatrixswitcher. Since upon loading, MLserver fails to see the plugin, I just draged and dropped the .dll file in the plugin directory. I suppose the imrproper install may be my problem? How can I properly install the plugin?
Wed Oct 04, 2006 9:43 am
digitaltrader,
Sounds like you've got an issue with where you are installing it. Just use the defaults for most plugins and you'll be fine. Opt to install it into
C:\Program Files\MLServer
It will create a subfolder called MLMatrixSwitcher off of your plugins folder.
Also, be sure to install MLMatrixSwitcher Family plugin:
http://www.cinemaronline.com/mlserver.m ... tcher.html
Return to “Video Storm”
