digitaltrader
Switcher Graphics
Wed Oct 04, 2006 11:46 am
I saw the advertisement on the toast forum for the Matrix plugin and have everything now successfully installed after your help. What I cannot find is the graphic you advertise on the toast forum for the switcher. Where can I find this graphic?
Wed Oct 04, 2006 12:03 pm
I believe the scenes in question are these:
They were designed using graphics from Library 0017 and Library 0014. You can easily replace the buttons with items from the core MainLobby libraries and the commands will remain attached to the buttons. I believe these scenes ship with Library0017. If you would like, I can email them to anyone interested.
digitaltrader
Wed Oct 04, 2006 1:55 pm
Hmmmm, do you have anything already setup to work with the provided libraries as I do not own the additional library set. I like the look of the graphics in the one you advertised on the toast forum am assumed that they came standard with the plugin.
Wed Oct 04, 2006 2:31 pm
digitaltrader, mario can provide the mls file that has the commands in them. You would just swap the current button IDs for button IDs from the standard libraries. Then, you would go into Design mode and move things around so they look good. So, 1/2 the work is done. You have to do the second half if you want to change the graphics.
Or, buy the optional librarys and save yourself the time :)
Sample Scenes
Wed Oct 04, 2006 4:13 pm
Here's the MLS Files.
0017_0025.mls
(22.86 KiB) Downloaded 67 times
0017_0025b.mls
(32.01 KiB) Downloaded 74 times
T.Wells
Sorry to dig up this thread
Tue Jul 03, 2007 11:17 pm
I am on the verge of picking up a VideoStorm CRM84. Are there any pre-designed scenes using the 019 MLS library?
If so, that may force may hand ...
T.Wells
Wed Jul 04, 2007 10:14 am
T. Wells,
0019_media.switcher.mls is included with the base install.
Return to “Video Storm”
