MLServer 3.75 Release notes and info
Mon Jun 01, 2009 12:47 am
MLServer 3.75 is now available for general download. It has replaced version 3.0.591 in MLInstaller.
This version uses a new registration email process. Emails are now sent directly to the Cinemar Email server using port 1501. This should eliminate activation requests going unanswered.
This version of MLServer also introduces a new MLWorker Agent process. Unlike the old agent that would spawn multiple copies of itself the new MLWorker Agent stays running whenever MLServer is running. The new multi-threaded Agent is doing a lot of the time consuming tasks that used to bog down MLServer.
Tue Jun 30, 2009 12:33 am
Version 3.75.33 of MLServer is available for download. This version resolves a issue related to incorrectly applying license keys under some circumstances.
Tue Jun 30, 2009 1:36 pm
06/30/2009 - Version 3.75.34
Adds the |NoCache switch to the web server GetImage command. Append this switch to the end of the URL to make sure an image is never retrieved from cache.
Sat Jul 11, 2009 6:45 pm
7/11/2007 Version 3.75.39
Updates the MLWorker_Agent to support downloads of all valid web image formats and not just JPeg files.
Re: MLServer 3.75 Release notes and info
Fri Aug 21, 2009 1:41 pm
08/21/2009 - Version 3.75.54
Includes new MLWorker_Agent that restores Amazon cover art lookups for MusicLobby and DVDLobby.
Updates GetImage routines to use MLServer DNS name when looking for local files.
Includes new Family Manager routines to support new plugin Family Manager linking protocol.
Mon Aug 31, 2009 8:13 pm
08/31/2009 - Version 3.75.56
Updates GetImage routines to use MLServer DNS name and local name when looking for local files.
Resolves an issue with SendMessage command not sending the email message.
Tue Sep 01, 2009 5:13 pm
09/01/2009 - Version 3.75.67
Additional updates to the GetImage routine. Should eliminate failed downloads for rapidly updating images such as from security cameras.
Sun Sep 27, 2009 5:28 pm
9/27/2009 Version 3.75.70
Modifies the MLServer Macro command to support nested Macros. That is Macros that call other Macros. In order to use this feature all you have to do is modify the macro delimiter on each nested level. The innermost macro will use a single ! as the delimiter. The next layer out will use !! as the delimiter, the next outer layer will use !!!. Macros can be nested up to 4 levels deep with this version.
For example:
Macro|MLConditional|IsEqual##Something##1##Macro|Setvariable|Var1~1!SetVariable|Var2~2##Macro|Setvariable|Var1~3!SetVariable|Var2~4##!!SetVariable|AllDone~1
bigDvette
Sun Sep 27, 2009 6:57 pm
me like
ricks
Sun Sep 27, 2009 10:47 pm
Holy Conditional, Batman! This is huge!!!
Tue Sep 29, 2009 5:49 pm
9/29/2009 Version 3.75.71
Modifies the Macro processing logic to accept Macro commands that only contain one MLServer command.
Macro|MLCmd|{{clientname}}~setProperty|RemoteFX2~move~-1024~0~2 is technically not a macro since it only includes one step. It would comsume less CPU cycles if the command was simply MLCmd|{{clientname}}~setProperty|RemoteFX2~move~-1024~0~2
However it should be valid to issue such a command and the macro processing change that was in v70 didn't allow for this condition.
MLServer 3.75.71 has been updated to allow for this syntax.
ronsatter
Wed Sep 30, 2009 12:02 am
Thanks Dave. That keeps things consistent. As a matter of practice, I often start a macro with only one command, save it and then come back to add other commands as necessary. So I have lots of macros with only one command. And if I'm not mistaken, when you create a new macro, it always adds "Macro|" to the first command ... so it's much better to let it be. What's a few extra CPU cycles among friends. :lol:
Blade
Tue Oct 13, 2009 10:01 pm
There is a new MLServer on 10/13/2009
What has changed since .71?
Tue Oct 13, 2009 10:23 pm
10/13/2009 Version 3.75.74
Added support for internal commands for the new MLCX7000ES plugin for the Sony BDP-7000ES Mega Changer.
No other MLServer changes in this release.
Fri Nov 06, 2009 3:41 pm
11/06/2009 Version 3.75.76
Updated the GetImage function call to resolve an issue with missing thumbnails for users still using the old DVDLobby.swf files.
Return to “MLServer 3”
