Ranger Home Automation
Thermostat thread
Sat Jul 19, 2008 4:56 pm
Cycling thru fan, mode and hold works fine. When the command is sent from ML, it only takes about a second for the command to get to the physical thermostat. THATS GREAT!!
However, to get the update back to the ml screen it never takes less than ten seconds and most of the time it takes about fourteen seconds. Example, turn fan ON:
Physical Fan actually turns on in about one second. WOOHOO!!!
The thermostat GUI wont show ON until after at least 10-14 seconds
(Same with mode and hold)
I assume this is because the "POLL STATUS EVERY" is set to 15 seconds. If I change that to 2 seconds, wont that tax my CPU? Is there a way to have a particular event polled based on the command sent? Meaning if i send a thermostat command have it polled so it reflects immediatly in ML? I am thinking we want to avoid having all status's polled every second or two. PCAccess is pretty immediate.
Sat Jul 19, 2008 5:21 pm
Your assumptions are correct. I'll add a poll of the tstat immediately after a tstat command in the next release.
Adjusting Thermostat up or down one degree at a time.
Sat Jul 19, 2008 7:19 pm
Wow, did I actually CONTRIBUTE something finally? :)
I dont see in the Agent where there any commands to incrementally increase the temp up or down one degree at a time. This, of course, is possible via the actual thermostat. Is there proper syntax for it to be done thru ML?
My apologies if this has been addressed already. My search did not yield anything.
Sun Jul 20, 2008 12:20 am
Version 3.0.3122.38039 of the agent add Inc and Dec functions to Thermostat Heat and Cool setpoints and adds an immediate feedback poll when a TStat or Unit command is issued.
Sun Jul 27, 2008 10:23 am
Thermostat functions are working well. I still am using a macro to adjust temperature, which actually offers bennifits if communications is lost.
Macro for heat SP Up is;
Macro|
MLMath|Add~HeatSP~{{hai_thermostat001_heatsetpointfround}}~1!
MLServeCmd.MLHAI|001~TStat~1~HeatF~{{HeatSP}}
ricks
Sun Jul 27, 2008 10:49 am
One other odd thing with the tstats is that the options for Hold are Hold and On. Seems to be the same thing.
Rick
Sun Jul 27, 2008 11:07 am
Yep - should be ON and OFF
Fan works OK with the options of ON and AUTO
Sun Jul 27, 2008 4:26 pm
Yes, typo on my part, it should be Off and Hold. It's fixed in the next release.
Return to “MLHAI Beta”
