MLHAI Plugin release date 10-06-2006
Fri Oct 06, 2006 8:43 pm
Install without issue
initial load of MLServer with MLHAI plugin no error
License applied correctly
Access Com port properly
Login to HAI OMNI Pro II fine
Run setup.....obtains zone information correctly
Start polling zones
MLSERVER crash
MLServer log abrupt stop at crash
MLHAI log abrupt stop at crash
Windows event log
Event Type: Information
Event Source: .NET Runtime 2.0 Error Reporting
Event Category: None
Event ID: 1001
Date: 10/6/2006
Time: 8:31:55 PM
User: N/A
Computer: MLSERVER
Description:
Bucket 333645592, bucket table 1, faulting application mlserver.exe, version 3.0.0.97, stamp 451ab5b1, faulting module msxml3.dll, version 8.50.2162.0, stamp 4110975c, debug? 0, fault address 0x0002caad.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 42 00 75 00 63 00 6b 00 B.u.c.k.
0008: 65 00 74 00 3a 00 20 00 e.t.:. .
0010: 33 00 33 00 33 00 36 00 3.3.3.6.
0018: 34 00 35 00 35 00 39 00 4.5.5.9.
0020: 32 00 0d 00 0a 00 42 00 2.....B.
0028: 75 00 63 00 6b 00 65 00 u.c.k.e.
0030: 74 00 54 00 61 00 62 00 t.T.a.b.
0038: 6c 00 65 00 20 00 31 00 l.e. .1.
0040: 0d 00 0a 00 ....
Event Type: Error
Event ID: 1000
Date: 10/6/2006
Time: 8:31:31 PM
User: N/A
Computer: MLSERVER
Description:
Faulting application mlserver.exe, version 3.0.0.97, stamp 451ab5b1, faulting module msxml3.dll, version 8.50.2162.0, stamp 4110975c, debug? 0, fault address 0x0002caad.
Data:
0000: 41 00 70 00 70 00 6c 00 A.p.p.l.
0008: 69 00 63 00 61 00 74 00 i.c.a.t.
0010: 69 00 6f 00 6e 00 20 00 i.o.n. .
0018: 46 00 61 00 69 00 6c 00 F.a.i.l.
0020: 75 00 72 00 65 00 20 00 u.r.e. .
0028: 20 00 6d 00 6c 00 73 00 .m.l.s.
0030: 65 00 72 00 76 00 65 00 e.r.v.e.
0038: 72 00 2e 00 65 00 78 00 r...e.x.
0040: 65 00 20 00 33 00 2e 00 e. .3...
0048: 30 00 2e 00 30 00 2e 00 0...0...
0050: 39 00 37 00 20 00 34 00 9.7. .4.
0058: 35 00 31 00 61 00 62 00 5.1.a.b.
0060: 35 00 62 00 31 00 20 00 5.b.1. .
0068: 69 00 6e 00 20 00 6d 00 i.n. .m.
0070: 73 00 78 00 6d 00 6c 00 s.x.m.l.
0078: 33 00 2e 00 64 00 6c 00 3...d.l.
0080: 6c 00 20 00 38 00 2e 00 l. .8...
0088: 35 00 30 00 2e 00 32 00 5.0...2.
0090: 31 00 36 00 32 00 2e 00 1.6.2...
0098: 30 00 20 00 34 00 31 00 0. .4.1.
00a0: 31 00 30 00 39 00 37 00 1.0.9.7.
00a8: 35 00 63 00 20 00 66 00 5.c. .f.
00b0: 44 00 65 00 62 00 75 00 D.e.b.u.
00b8: 67 00 20 00 30 00 20 00 g. .0. .
00c0: 61 00 74 00 20 00 6f 00 a.t. .o.
00c8: 66 00 66 00 73 00 65 00 f.f.s.e.
00d0: 74 00 20 00 30 00 30 00 t. .0.0.
00d8: 30 00 32 00 63 00 61 00 0.2.c.a.
00e0: 61 00 64 00 0d 00 0a 00 a.d.....
will now return to the plugin and continue the startup process.
MLSERVER 97
HAI plugin just downloaded.
All hai plugins loaded (will unload theater tek on a later test)
Fri Oct 06, 2006 9:03 pm
Second load
No errors on second server start with MLHAI plugin running.
unfortunately, plugin does not create any variables........
stopping server and will restart.
Plugin still does not allow hot load/unload (most other ML plugins do allow this, can be started or stopped or restarted without requiring an MLServer shutdown and restart.
Fri Oct 06, 2006 9:18 pm
Is it now working?
Did you do a PC reboot?
I will point Raj to this thread to see what he thinks.
Fri Oct 06, 2006 9:28 pm
very interesting.....
The plugin obviously logged into the omni because it built all the correct zones and placed them in the ini file.
It did NOT create the variables.....and of course didn't populate them....because they weren't there.
I have stopped and restarted MLServer several times with no change in this situation. Opening the MLHAI plugin and requesting the OMNI log was also not successful.....just a blank page.
so, yes.....just fired up a complete reboot.
our next report when it comes up.
Fri Oct 06, 2006 9:30 pm
ChrisB,
Try backing up the .ini file and renaming it so the plugin creates a new one. Then, reconfigure the port and login and try again.
There is the possibility that something changed in the .ini format.
Fri Oct 06, 2006 9:44 pm
Reboot but no change......plugin loads....log shows
polling
Polling for System Events ..
Getting the Auxilary Systems Status ...
I had done this when loading the plugin.....removed the old ini file and allow the plugin to create a new ini.
It did.....found the correct zones and units, etc. just does not create variables....
will delete all MLHAI and start over.....
btw....CallerID is working.....
Fri Oct 06, 2006 10:00 pm
reboot.....again and rebuild again.
Got a little farther this time.....actually started polling and entering information into the log and then MLServer crash with same.net error.
Also this time from the MLServer log
10/6/2006 9:53:16 PM Error SendIt Error# 5 - raised by SendIt
10/6/2006 9:53:22 PM Error SendIt Error# 5 - raised by SendIt
10/6/2006 9:53:24 PM Error SendIt Error# 5 - raised by SendIt
10/6/2006 9:53:29 PM Error SendIt Error# 5 - raised by SendIt
attaching logs. this time looks like TT got in the way. will disable tt and move forward.
MLServer-20061006.zip
(79.68 KiB) Downloaded 21 times
Fri Oct 06, 2006 10:10 pm
NO MLDevice Manager (TT)
MLHAI variables being created.
MLHS Plugin Run-time error '-2147417848 (80010108)':
Automation error
The object invoked has disconnected from its clients
crash
Event Type: Error
Event ID: 1000
Date: 10/6/2006
Time: 10:09:07 PM
User: N/A
Computer: MLSERVER
Description:
Faulting application mlserver.exe, version 3.0.0.97, stamp 451ab5b1, faulting module mlserver.exe, version 3.0.0.97, stamp 451ab5b1, debug? 0, fault address 0x0010ea3b.
Data:
0070: 6c 00 73 00 65 00 72 00 l.s.e.r.
0078: 76 00 65 00 72 00 2e 00 v.e.r...
0080: 65 00 78 00 65 00 20 00 e.x.e. .
0088: 33 00 2e 00 30 00 2e 00 3...0...
0090: 30 00 2e 00 39 00 37 00 0...9.7.
0098: 20 00 34 00 35 00 31 00 .4.5.1.
00a0: 61 00 62 00 35 00 62 00 a.b.5.b.
00a8: 31 00 20 00 66 00 44 00 1. .f.D.
00b0: 65 00 62 00 75 00 67 00 e.b.u.g.
00b8: 20 00 30 00 20 00 61 00 .0. .a.
00c0: 74 00 20 00 6f 00 66 00 t. .o.f.
00c8: 66 00 73 00 65 00 74 00 f.s.e.t.
00d0: 20 00 30 00 30 00 31 00 .0.0.1.
00d8: 30 00 65 00 61 00 33 00 0.e.a.3.
00e0: 62 00 0d 00 0a 00 b.....
Will turn off MLHSPlugin
Fri Oct 06, 2006 10:21 pm
okay....if you give me an RSS reader I can turn off MLHSPlugin for good.....
Then all we have is TT to figure out.
MLHAI has gone through a full set of polls, built all its variables and hasn't crashed......
A very good sign!
It has picked up conditions of all my variables quite nicely right down to lighting dim settings, flag settings...all in language I can use.
RAJ RAJ HE's our MAN!
Sorry....it's Friday night....gotta have a little football humor!
Seriously.....this could be THE ONE....
commands seem to work so far.....so good.....
Fri Oct 06, 2006 10:35 pm
Just to be certain, I went back through the whole scenario.
MLHAI plugin will not tolerate MLDevice Manager and TT plugin by itself
MLHAI plugin will not tolerate MLHSPlugin by itself
together or singularly.....they do not get along.
btw..ML.TT and MLHS work together.....just not with MLHAI
BUT....the GREAT news is this version of the MLHAI plugin looks like something Cinemar can be proud of!
Fri Oct 06, 2006 10:39 pm
you just happened to have one in your pocket?
That was fast!
THX
Fri Oct 06, 2006 11:38 pm
I may have spoken too soon....
regular crashes on startup. ......same DOT>NET error
Now they just wont go away
MLserver unstable if HAI running....
ML event logs attached as well as ML. and MLHAI and a screenshot of my active running plugins
sorry...really looked good for awhile.
MLHAI_err.zip
(259.9 KiB) Downloaded 25 times
Fri Oct 06, 2006 11:44 pm
ChrisB,
What OS and what patch level are you at? Do you have .Net2 w/ service packs? I don't know if the plugin requires it, but I was curious.
Mine is working well. Running the last two days without a hickup.
XPPro SP2, all updates.
Fri Oct 06, 2006 11:52 pm
same here.....
XP SP2 and right up to today's MS releases and the latest .net security update KB917283
two curious observations......
after startup the last couple of times MLServer opened two instances of Insteon SDM.....
I just downloaded and installed the latest MLLIghting family....
Also.....apparently lost my xlate at the firewall and couldn't internet.....so MLWx was upset.
Running again.....hai loaded again....will leave it alone and see how long it runs. turned logging down to errors only
Fri Oct 06, 2006 11:59 pm
didn t take long.....
crash
.net
server loads completely......on second poll of Omni, server crashes.
From the HAI log it had just finished the first thermostat and then stopped.
disable HAI now and see if i get the .net runtime
Return to “MLHAI Beta”
