TheCodeMan
Sat Jun 14, 2008 12:16 am
It looks like it has updated correctly now. I will do some more testing and update with the results.
Sat Jun 14, 2008 12:17 am
Are you getting Weather data and Horoscope data being returned to MLServer from MLWorker?
TheCodeMan
Sat Jun 14, 2008 12:43 am
Ok, I'm getting close. MLTimer is working correctly. MLPing is working correctly. The automation rule is now my issue. I currently have the rule set to:
Whenever server_209.85.173.103_internetstate equals 0
Then MLServeCmd.Macro|Lighting.0002|SwitchPower_Off!MLPause|5!MLighting.0002|SwitchPower_On
I suspect the syntax is incorrect on this. The Power Off command is working correctly. After 5-10 seconds, there is no power on, however. Any ideas?
Sat Jun 14, 2008 12:56 am
do you see the three commands in the Macro being executed in MLServer's event log? Can you run this macro by hand? Does it work?
TheCodeMan
Sat Jun 14, 2008 1:12 am
Here is what I am seeing.
Sat Jun 14, 2008 1:35 am
The MLInsteonPLM plugin is throwing errors. It does not like the Power commands your are issuing. If you just issue the power off and power on commands by hand do they work?
TheCodeMan
Sat Jun 14, 2008 1:43 am
They seem to work fine by using the InsteonPLM GUI. I can turn off 0002 and turn it back on (my broadband router) and it works every time manually.
Sat Jun 14, 2008 1:54 am
The problem is in the MLInsteonPLM plugin or the commands you are using. Do those commands work when you issue them to MLServer?
and
Sat Jun 14, 2008 9:21 am
There is a typo. It's not MLighting. it's Lighting.
TheCodeMan
Sun Jun 15, 2008 11:24 pm
A simple typo, I overlooked it. That fixed the problem and it works perfectly now. Thanks for all the quick responses.
TheCodeMan
Tue Sep 02, 2008 9:46 pm
The end result for anyone interested in this thread. Below is a brief description of the plugins used to accomplish this task along with the respective commands.
Internet
This process pings the Internet every two minutes for a response. If no response is received, a command is issued to power the Internet router off and back on after a brief pause.
MLStartup Plugin – MLTimer|Enable~Internet is executed in the System.Startup script.
MLTimer Plugin – Timer 1 – Internet is set to run at an interval of 120 seconds. The Alias is Internet, and the MLServeCmd is MLPing|209.85.173.103. This is a repeating task. The results of this ping test update the Server Variable server_209.85.173.103_internetstate to 1 (pingable) or 0 (not pingable)
MLInsteonPLM Plugin - ID 0002 – Alias Internet Router is controlled via…
Automation Rule (1)
Then MLServeCmd.Macro|Lighting.0002|SwitchPower_Off!MLPause|5!Lighting.0002|SwitchPower_On
Let me know if you need any further explanation.
Tue Sep 02, 2008 10:10 pm
Nice.. thanx for sharing.
Not sure what the CQC fan boys are saying that MainLobby user's aren't into Home Automation ;)
Return to “Automation Rules”
