Climate Family Installation
About The Climate Family
The Climate Family is used to control multiple styles of thermostats with a network or RS-232 connection.It allows for standarized myServer scene configuration that the Climate Family then routes the commands to the appropriate Thermostat. This allows for scenes to be reusable across multiple Thermostat vendors. It also allows for usage of multiple concurrant thermostat controllers.
Installation "Climate.Type.Driver".dll
  1. Download the driver from myInstaller and install the driver that communicates with the type of thermostats connected to myServer5.
  2. With myServer shutdown, run the "Thermostat-Type"_Driver_exe. that coresponds to the type of thermostats you have connected. This will install Thermostat driver to the myServer/Driver directory.
It is recommended to accept all installation defaults.
Drivers available for this family driver are:
  • RadioThermostat- CT-30, CT-80, 3M-50 (Note more Thermostats will be added)
Settings
Configuring the alias and network IP address/ Com Port for each of your thermostats is done in the Family Manager.
Click on the Add button and enter in the IP address/ Com Port of your thermostat and its friendly alias.
To see the event logs, settings etc, open the selected device in the Device Driver tab.
myServer Commands:
SetInterval
Script Usage Climate|TStat#~SetInterval~Seconds Parameters TStat# = The Thermostat's ID or Alias Seconds = The desired seconds between pollings- 1..60 (Literal) Climate|1~SetInterval~30
Description
Queries the thermostats for its current status.
HeatSetpoint
Script Usage
Climate|TStat#~HeatSetpoint~Value Parameters TStat# = The Thermostat's ID or Alias Value = The desired temp or Up, Down (Literal) Climate|1~HeatSetpoint~78 Climate|1~HeatSetpoint~Up Climate|1~HeatSetpoint~
Down
Description
Sets the Heat Setpoint to the desired value or Up/Down by 1 degree.
CoolSetpoint
Script Usage
Climate|TStat#~CoolSetpoint~Value
Parameters TStat# = The Thermostat's ID or Alias Value = The desired temp or Up, Down (Literal) Climate|1~CoolSetpoint~78 Climate|1~CoolSetpoint~Up Climate|1~CoolSetpoint~
Down
Description
Sets the Cool Setpoint to the desired value or Up/Down by 1 degree.
Mode
Script Usage
Climate|TStat#~Mode~Value Parameters TStat# = The Thermostat's ID or Alias Value = The desired thermostat mode (Auto,Cool,Heat,Off,Emht) (Literal) Climate|1~Mode~
Auto
Description
Sets the Thermostat's HVAC operating mode.
Script Usage
Climate|TStat#~Fan~Value Parameters TStat# = The Thermostat's ID or Alias
Value = The desired thermostat fan mode (Auto,On) (Literal) Climate|1~Fan~
Auto
Description Sets the Thermostat's fan mode.
Hold
Script Usage
Climate|TStat#~Hold~Value Parameters TStat# = The Thermostat's ID or Alias Value = The desired hold state (Off,On) (Literal) Climate|1~Hold~
On
Description Sets the Thermostat's hold state.
Status
Script Usage
Climate|TStat#~Status Parameters TStat# = The Thermostat's ID or Alias (Literal) Climate|1~
Status
Description Queries the thermostasts for its current status.
myServer Variables
All the Server Variables for this Driver begin with the prefix Climate_TSTat#_ They will very some depending on the manufacture of the thermostat.
