CallerID Installation
Welcome to the myServer5 CallerID App
This App will create variables that enables your HTML5 clients to display CallerID information.
Requirements
•myServer5
•A compatible modem, Best Data 56k v.92/v.44 (#56HP) PCI Windows Internal Modem
•myServer5 HTML5 UI App.
Description
Most phone services provide telephone number and caller informtion with each call. A phone modem can extract this data. The CallerID App can record this data and allows for mapping of the phone number to a caller's name that is maintained in the callerid database.
Here is how the communication works: Telephone company > Incoming phone call > CallerID data > Modem (on PC com port) > CallerID App > callerid database > myServer 5 UI App
Install the modem with the latest drivers for your operating system. Note what comport the modem is installed to.
1. Shutdown myServer5
2. Download and install the CallerID App from myInstaller on the Primary myServer5 PC.
3. Start the myServer5 application.
4. Open the Server Apps window and make sure that the CallerID App is Enabled. Caller ID Enabled.jpg
Setup
1. Start myServer5 if not already started.
2. Double click on callerid plugin and click on Settings once the new window appears.
3. If you are using callerid with a PC modem ((Recommended model: US Robotics USR5633ACCS USB, Best Data 56k v.92/v.44 (#56HP) PCI Windows Internal Modem), then make sure the modem is installed properly with it’s software driver, and select the modem com port in the CallerID com port drop down. Do this for both phone lines if you are using two phone lines and modems. 4. Set up the image folders you want to use or leave them on the default folders. (Recommend default folders.)
CallerID Settings.jpg Events Tab 1. Click on the events tab to see curent events and to set up the logging for the App.. Importing Aliases from previous versions of callerid
1. Open the CallerID App.
2. Click on the Import button on the right side, select the location of your MLS3 data folder and select MLCallerID.mdb.
3. All of your aliases should now be in the list.
Adding an Alias
1. Open the callerid App.
2. Click on the Aliases tab at the top.
3. Click the Add button.
4. Enter the alias information in the empty data box that appearrs. CallerID images should be created at 480x640 for optimimum resolution
5. The new alias will now be in the list
Editing an Alias
3. Select the alias you wish to edit from the alias list and click on the data box you wish to edit.
Deleting an Alias
3. Select the alias you wish to delete from the alias list.
4. Click on the Delete button..
Clear the call log
2. Click on the Call Log tab at the top.
3. Click on the Delete All button.
Delete a call from the call log
1. Open the callerid plugin.
3. Select the call you wish to delete from the call list.
4. Click on the Delete button on the right. CallerID CallLog.jpg Contents [hide]
1 CallerID Supported Commands
2 CallerID myServer Variables
3 Bugs
4 Feature Requests
5 Release Notes
CallerID|Power Script Usage CallerID|Power (Literal) CallerID|Power Description This command turns the power of to the callerid plugin. This stops the on call command from being fired when you receive a call CallerID|FirstCaller Script Usage CallerID|FirstCaller (Literal) CallerID|FirstCaller Description Sets myServer variables for the first caller in the list. CallerID|LastCaller Script Usage CallerID|LastCaller (Literal) CallerID|LastCaller Description Sets myServer variables for the last caller in the list. Notes CallerID|Next Script Usage CallerID|Next (Literal) CallerID|Next Description Sets myServer variables for the next call in the list relative to the current caller being displayed. |CallerIDPrevious Script Usage CallerID|Previous (Literal) callerid|Previous Description Sets myServer variables for the previous call in the list relative to the current caller being displayed. CallerID|Delete Script Usage CallerID|Delete~Call # (Literal) CallerID|Delete~3 CallerID|Delete~1 Parameters Call # = The id of the call. Description Deletes the specified call from the call log. CallerID|FirstPage Script Usage CallerID|FirstPage (Literal) CallerID|FirstPage Description Sets the myServer variables for the first page of callers. The number of callers per page is determined by user settings. CallerID|LastPage Script Usage CallerID|LastPage (Literal) CallerID|LastPage Description Sets the myServer variables for the last page of callers. The number of callers per page is determined by user settings. |CallerID|NextPage Script Usage CallerID|NextPage (Literal) CallerID|NextPage Description Sets the myServer variables for the next page of callers. The number of callers per page is determined by user settings. This command works in a circular fashion; if you are on the last page of callers and issue this command it will go back to the first page of callers. CallerID|PreviousPage Script Usage CallerID|PreviousPage (Literal) CallerID|PreviousPage Description Sets the myServer variables for the previous page of callers. The number of callers per page is determined by user settings. This command works in a circular fashion, if you are on the first page of callers and issue this command it will go back to the last page of callers. CallerID|ClearLog Script Usage CallerID|ClearLog (Literal) CallerID|ClearLog Description: Clears the Call Log CallerID myServer Variables The CallerID App will auto generate variables in myServer5 based on the settings you have entered. It will also update and create variables based on certain modem events. If possible all variables are set on startup. callerid_power callerid_active_page callerid_pagetotal callerid_lastcall_id_### callerid_lastcall_date_### callerid_lastcall_day_### callerid_lastcall_image_### callerid_lastcall_name_### callerid_lastcall_companyname_### callerid_lastcall_telephonenumber_### callerid_lastcall_time_### callerid_page_id_### callerid_page_date_### callerid_page_day_### callerid_page_name_### callerid_page_companyname_### callerid_page_time_### callerid_page_telephonenumber_### callerid_page_image_###
