Welcome to the Weather App for myServer5.
The Weather App uses your Internet connection to download the current and future weather conditions for any number of locations. It creates myServer variables with this information so that you can build custom user interface scenes to display the weather. Because this weather data is contained in myServer variables, you can also leverage that data for weather related automation logic. An example would be to shut down the Irrigation Family from watering the lawn if the forecast was for rain.
System Requirements
  • myServer5 or later
  • Microsoft Windows (Vista, 7, 8, 10)
  • PC with persistent Internet connection
Download and run the Weather App from myInstaller on the primary myServer PC. You can optionally download the sample weather scenes HTML5 for myServer and install them on your myServer PC.
Restart myServer.
Adding Locations
    1. Open the Weather App.
    2. Click on the Locations tab at the top.
    3. Click on the New Location button on the toolbar.
      1. Enter the 5 digit zipcode or location name and press Find Location button.
      2. Select the location from the list of items returned and double click it to add it to the Weather App.
      3. Once it is added to the location tab select if you want current conditions, tides and pollen information.
Removing Locations
      1. 1. Open the myWeather App.
      2. Click on the locations tab at the top.
      3. Select the locations to remove in the grid and then click on the Delete Location button on the toolbar.
Adding Maps
      2. Click on the Maps tab at the top.
      3. Click on the New Map button on the toolbar.
      4. Enter the description and URL of the map in the apprppriate fields.
      5. Click Save.
Removing Maps
      3. Select the maps to be removed in the grid and click on the delete button on the toolbar.
General Settings
      2. Click on the Setting tab at the top.
      3. Set the weather update interval. 20 minutes is the the default and minimum time between updates.
      4. On this page you can select to automatically resize a map and set the map size.
      5. Select if you want to use Metric Measurements and if you want to use V3 variable prefixes.
Supported Commands
Active
Script Usage: Weather|Active~Number/Zip Code/Location ID
(Literal):
Weather|Active~1
Weather|Active~12345
Weather|Active~USWI0644
Parameters
Number/Zip Code/Location ID = The number, zip code, or location id of the location you wish to set to active.
Description: Sets the Active location.
Register
Script Usage: Weather|Register~Number~Zip Code/Location ID
(Literal):
Weather|Register~1~12345
Weather|Register~2~USWI0644
Parameters:
Number = The number of the new location Zip Code.
Zip Code/Location ID = The zip code or location of the new location.
Description: Registers a new location to be monitored.
Next
Script Usage: Weather|Next
(Literal): Weather|Next
Parameters: None =
Description: Sets the active location to the next one in the list. This command works in a circular fashion when the end of the list is reached it goes back to the beginning.
Previous
Script Usage: Weather|Previous
      (Literal): Weather|Previous
Parameters None =
Description: Sets the active location to the previous one in the list. This command works in a circular fashion when the beginning of the list is reached it goes back to the end.
ActiveMap
Script Usage: Weather|ActiveMap~Number
      (Literal)
Weather|ActiveMap~1
Weather|ActiveMap~2
Weather|ActiveMap~3
Parameters
Number = The number of the map you wish to make the active map. Description Sets the active map to the map with the specified number.
PreviousMap
Script Usage: Weather|PreviousMap
(Literal):Weather|PreviousMap
Parameters None =
Description: Sets the active map to the next map in the list. This command works in a circular fashion, when the end of the list is reached it goes back to the beginning.
NextMap
Script Usage: Weather|NextMap
(Literal): Weather|NextMap
Parameters None =
Description: Sets the active map to the previous map in the list. This command works in a circular fashion, when the beginning of the list is reached it goes back to the end.
myServer Variables
Weather App Server Variables
The Weather App will auto generate variables in myServer based on the settings you have entered. It will also update variables in certain circumstances such as changing the active location. These are most of the variables, look at the myServer Variables for current variables generated.
      • Weather_city
      • Weather_climatestn
      • Weather_country
      • Weather_countryfips
      • Weather_county
      • Weather_countyfips
      • Weather_daily_reportedby
      • Weather_distanceunits
      • Weather_hourly_reportedby
      • Weather_icon
      • Weather_iconimage
      • Weather_isdayligthsavings
      • Weather_location#_city
      • Weather_location#_county
      • Weather_location#_id
      • Weather_location#_state
      • Weather_location#_zipcode
      • Weather_locationid
      • Weather_latitude
      • Weather_longtitude
      • Weather_measurementsunits
      • Weather_measurementsunitsalt
      • Weather_observesdaylightsavings
      • Weather_primaryairport
      • Weather_primarytide
      • Weather_primaryzipcode
      • Weather_speedunits
      • Weather_state
      • Weather_stateabbr
      • Weather_tempunits
      • Weather_tempunitslong
      • Weather_timezone
      • Weather_units
      • Weather_uvindex
      • Weather_weatherstation
10 Day forecast
      • Weather_forecast_#_chanceprecip
      • Weather_forecast_#_chanceprecipday
      • Weather_forecast_#_chanceprecipnight
      • Weather_forecast_#_chancesnow
      • Weather_forecast_#_cloudcoverageday
      • Weather_forecast_#_date
      • Weather_forecast_#_dateday
      • Weather_forecast_#_dateutc
      • Weather_forecast_#_dateyear
      • Weather_forecast_#_day
      • Weather_forecast_#_dayf
      • Weather_forecast_#_dayc
      • Weather_forecast_#_dayshort
      • Weather_forecast_#_dow
      • Weather_forecast_#_hitempf
      • Weather_forecast_#_hitempc
      • Weather_forecast_#_icon
      • Weather_forecast_#_iconcode
      • Weather_forecast_#_iconcodeday
      • Weather_forecast_#_iconcodenight
      • Weather_forecast_#_iconimage
      • Weather_forecast_#_lotempf
      • Weather_forecast_#_lotempc
      • Weather_forecast_#_month
      • Weather_forecast_#_moondescr
      • Weather_forecast_#_moonphase
      • Weather_forecast_#_moonrise
      • Weather_forecast_#_moonset
      • Weather_forecast_#_nightf
      • Weather_forecast_#_nightc
      • Weather_forecast_#_relhumidityday
      • Weather_forecast_#_relhumiditynight
      • Weather_forecast_#_skycode
      • Weather_forecast_#_skycodeday
      • Weather_forecast_#_skycodenight
      • Weather_forecast_#_skytext
      • Weather_forecast_#_skytextday
      • Weather_forecast_#_skytextnight
      • Weather_forecast_#_sunrise
      • Weather_forecast_#_sunset
      • Weather_forecast_#_uvdescr
      • Weather_forecast_#_uvindex
      • Weather_forecast_#_uvwarn
      • Weather_forecast_#_winddegreesday
      • Weather_forecast_#_winddegreesnight
      • Weather_forecast_#_winddirectionday
      • Weather_forecast_#_winddirectionnight
      • Weather_forecast_#_windspeedkmday
      • Weather_forecast_#_windspeedknday
      • Weather_forecast_#_windspeedkmnight
      • Weather_forecast_#_windspeedknnight
      • Weather_forecast_#_windspeedmphday
      • Weather_forecast_#_windspeedmphnight
Current Observation
      • Weather_Current_ReportTime
      • Weather_Current_DateYear
      • Weather_Current_DateMonth
      • Weather_Current_DateDay
      • Weather_Current_DateHour
      • Weather_Current_DateMinute
      • Weather_Current_DateSecond
      • Weather_Current_DateDOW
      • Weather_Current_TempF
      • Weather_Current_TempC
      • Weather_Current_DewPointF
      • Weather_Current_DewPointC
      • Weather_Current_RelHumidity
      • Weather_Current_WindSpeedMPH
      • Weather_Current_WindDirectionDegrees
      • Weather_Current_WindGustsMPH
      • Weather_Current_Pressure
      • Weather_Current_Weather
      • Weather_Current_Sky
      • Weather_Current_Icon
      • Weather_Current_Ceiling
      • Weather_Current_Visibility
      • Weather_Current_HeatIndexF
      • Weather_Current_HeatIndexC
      • Weather_Current_WindChillF
      • Weather_Current_WindChillC
      • Weather_Current_FeelsLikeF
      • Weather_Current_FeelsLikeC
      • Weather_Current_SnowDepth
      • Weather_Current_SixHrMaxTemp
      • Weather_Current_TwentyFourHrMaxTemp
      • Weather_Current_SixHrMinTemp
      • Weather_Current_TwentyFourHrMinTemp
      • Weather_Current_ThreeHrPrecip
      • Weather_Current_SixHrPrecip
      • Weather_Current_TwentyFourHrPrecip
      • Weather_Current_CodedWeather
      • Weather_Current_EnhancedWeather
      • Weather_Current_ReportText
Historic Average
      • Weather_Historic_StationName
      • Weather_Historic_Month
      • Weather_Historic_Date
      • Weather_Historic_Interval
      • Weather_Historic_AvgHiF
      • Weather_Historic_AvgHiC
      • Weather_Historic_AvgLoF
      • Weather_Historic_AvgLoC
      • Weather_Historic_RecordHiF
      • Weather_Historic_RecordHiC
      • Weather_Historic_RecordHiDate
      • Weather_Historic_RecordLoF
      • Weather_Historic_RecordLoC
      • Weather_Historic_RecordLoDate
      • Weather_Historic_MeanTempF
      • Weather_Historic_MeanTempC
      • Weather_Historic_AvgPrecipIn
      • Weather_Historic_AvgPrecipCm
      • Weather_Historic_AvgSnowIn
      • Weather_Historic_AvgSnowCm
Hourly Forecast
      • Weather_HF_ReportTime
      • Weather_HF 1..48 _DOW
      • Weather_HF 1..48 _DateUTC
      • Weather_HF 1..48 _DateYear
      • Weather_HF 1..48 _DateMonth
      • Weather_HF 1..48 _DateDay
      • Weather_HF 1..48 _DateHour
      • Weather_HF 1..48 _DateMinute
      • Weather_HF 1..48 _DateSecond
      • Weather_HF 1..48 _DateDOW
      • Weather_HF 1..48 _TempF
      • Weather_HF 1..48 _TempC
      • Weather_HF 1..48 _SkyCode
      • Weather_HF 1..48 _SkyCodeExt
      • Weather_HF 1..48 _Icon
      • Weather_HF 1..48 _SkyL
      • Weather_HF 1..48 _SkyM
      • Weather_HF 1..48 _SkyS
      • Weather_HF 1..48 _ChancePrecip
      • Weather_HF 1..48 _ChanceSnow
      • Weather_HF 1..48 _RelHumidity
      • Weather_HF 1..48 _WindSpeedMPH
      • Weather_HF 1..48 _WindSpeedKM
      • Weather_HF 1..48 _WindSpeedKN
      • Weather_HF 1..48 _WindDegrees
      • Weather_HF 1..48 _WindDirection
      • Weather_HF 1..48 _HeatIndexF
      • Weather_HF 1..48 _HeatIndexC
      • Weather_HF 1..48 _WindChillF
      • Weather_HF 1..48 _WindChillC
      • Weather_HF 1..48 _VisibilityMI
      • Weather_HF 1..48 _VisibilityKM
      • Weather_HF 1..48 _CloudCoverage
      • Weather_HF 1..48 _DewPointF
      • Weather_HF 1..48 _DewPointC
      • Weather_HF 1..48 _UVIndex
      • Weather_HF 1..48 _UVDescr
      • Weather_HF 1..48 _UVWarn
Weather Alerts
      • Weather_Alert_Count
      • Weather_Alert#_CountryFIPS
      • Weather_Alert#_StateAbbr
      • Weather_Alert#_Type
      • Weather_Alert#_StartTime
      • Weather_Alert#_EndTime
      • Weather_Alert#_Headline
      • Weather_Alert#_Bulletin
      • Weather_Alert#_URL
      • Weather_Alert#_Category
      • Weather_Alert#_Urgency
      • Weather_Alert#_Severity
      • Weather_Alert#_Certainty
      • Weather_Alert#_Geoname
      • Weather_Alert#_StateName
      • Weather_Alert#_CountyName
Tides
      • Weather_Tide_Distance
      • Weather_Tide_CityName
      • Weather_Tide_CityLatitude
      • Weather_Tide_CityLongtitude
      • Weather_Tide_Count
      • Weather_Tide_Reportedby
      • Weather_Tide 1..n _Date
      • Weather_Tide 1..n _TimeZone
      • Weather_Tide 1..n _FirstHiTide
      • Weather_Tide 1..n _FirstHiTideHeight
      • Weather_Tide 1..n _SecondHiTide
      • Weather_Tide 1..n _SecondHiTideHeight
      • Weather_Tide 1..n _FirstLoTide
      • Weather_Tide 1..n _FirstLoTideHeight
      • Weather_Tide 1..n _SecondLoTide
      • Weather_Tide 1..n _SecondLoTideHeight
      • Weather_Tide 1..n _Sunrise
      • Weather_Tide 1..n _Sunset
Ski Resort
      • Weather_Ski_CityID
      • Weather_Ski_Name
      • Weather_Ski_CityName
      • Weather_Ski_StateAbbr
      • Weather_Ski_ZipCode
      • Weather_Ski_Latitude
      • Weather_Ski_Longtitude
      • Weather_Ski_BaseElevation
      • Weather_SkiConditions_crosscountrykm
      • Weather_SkiConditions_snowmakingpercent
      • Weather_SkiConditions_snowmakingtrails
      • Weather_SkiConditions_groomingpercent
      • Weather_SkiConditions_groomingtrails
      • Weather_SkiConditions_hastubinglift
      • Weather_SkiConditions_tubinglanes
      • Weather_SkiConditions_tubinglocation
      • Weather_SkiConditions_tubinghours
      • Weather_SkiConditions_halfpipelocation
      • Weather_SkiConditions_terrainparklocation
      • Weather_SkiConditions_terrainparkfeatures
      • Weather_SkiConditions_halfpipeterrainother
      • Weather_SkiConditions_currentweather
      • Weather_SkiConditions_currenttemperature
      • Weather_SkiConditions_forecastweather
      • Weather_SkiConditions_forecasttemperature
      • Weather_SkiConditions_roads
      • Weather_SkiConditions_winds
      • Weather_SkiConditions_visibility
      • Weather_SkiConditions_suggestedtrails
      • Weather_SkiConditions_hasiceskating
      • Weather_SkiConditions_haswalkingtrails
      • Weather_SkiConditions_hassledding
      • Weather_SkiConditions_hascurling
      • Weather_SkiConditions_crosscountrynotes
      • Weather_SkiConditions_descent
      • Weather_SkiConditions_runconditions
      • Weather_SkiConditions_specialevents
      • Weather_SkiConditions_avalancherisk
      • Weather_SkiConditions_crosscountrysingletrack
      • Weather_SkiConditions_crosscountryskatingkm
      • Weather_SkiConditions_crosscountryopentrails
      • Weather_SkiConditions_latitude
      • Weather_SkiConditions_longitude
      • Weather_SkiConditions_cityname
      • Weather_SkiConditions_physicaladdressshort
      • Weather_SkiConditions_zipcode
      • Weather_SkiConditions_physicaladdresslong
      • Weather_SkiConditions_secondarysurface
      • Weather_SkiConditions_snowcomments
      • Weather_SkiConditions_hoursopen
      • Weather_SkiConditions_nighttrails
      • Weather_SkiConditions_nightlifts
      • Weather_SkiConditions_hascrosscountry
      • Weather_SkiConditions_issnowmaking
      • Weather_SkiConditions_isgrooming
      • Weather_SkiConditions_hashalfpipe
      • Weather_SkiConditions_hasterrainpark
      • Weather_SkiConditions_projectedterrain
      • Weather_SkiConditions_totaltrails
      • Weather_SkiConditions_totalmiles
      • Weather_SkiConditions_totalacres
      • Weather_SkiConditions_totallifts
      • Weather_SkiConditions_lastsnow
      • Weather_SkiConditions_previoussnow
      • Weather_SkiConditions_phonenumber
      • Weather_SkiConditions_stateabbreviation
      • Weather_SkiConditions_areaname
      • Weather_SkiConditions_reporttime
      • Weather_SkiConditions_newsnow24hours
      • Weather_SkiConditions_primarysurface
      • Weather_SkiConditions_averagebase
      • Weather_SkiConditions_trailsopen
      • Weather_SkiConditions_liftsopen
      • Weather_SkiConditions_milesopen
      • Weather_SkiConditions_acresopen
      • Weather_SkiConditions_percentopen
      • Weather_SkiConditions_hasnightskiing
      • Weather_SkiConditions_openstatus
      • Weather_SkiConditions_crosscountryopenkm
      • Weather_SkiConditions_entrytype
      • Weather_SkiConditions_lastsnowamount
      • Weather_SkiConditions_previoussnowdate
      • Weather_SkiConditions_previoussnowamount
      • Weather_SkiConditions_seasontotalsnow
      • Weather_SkiConditions_newsnowminimum
      • Weather_SkiConditions_newsnowmaximum
      • Weather_SkiConditions_baseminimum
      • Weather_SkiConditions_basemaximum
      • Weather_SkiConditions_lastsnowdate
Pollen Forecast
    • Weather_PF 1..n _DayNum
    • Weather_PF 1..n _Grass_Date
    • Weather_PF 1..n _Grass_Pollendescr
    • Weather_PF 1..n _Grass_Pollindex
    • Weather_PF 1..n _Grass_Reportime
    • Weather_PF 1..n _Grass_Station
    • Weather_PF 1..n _Grass_utcdate
    • Weather_PF 1..n _Pollentype
    • Weather_PF 1..n _Tree_Date
    • Weather_PF 1..n _Tree_Pollendescr
    • Weather_PF 1..n _Tree_Pollindex
    • Weather_PF 1..n _Tree_Reportime
    • Weather_PF 1..n _Tree_Station
    • Weather_PF 1..n _Tree_utcdate
    • Weather_PF 1..n _Weed_Date
    • Weather_PF 1..n _Weed_Pollendescr
    • Weather_PF 1..n _Weed_Pollindex
    • Weather_PF 1..n _Weed_Reportime
    • Weather_PF 1..n _Weed_Station
    • Weather_PF 1..n _Weed_utcdate
    • Weather_Pollen_Reportedby
