Autelis Pool Controller Installation
Autelis Pool Controller installation for myServer.
Autlelis supports both Pentair and Jandy pool controllers.  myServer now supports Autelis.  So, you can view the status of your pool or spa and control it's primary functions from a myServer user interface.  Sit in your hot tub, grab your water resistent iPhone 7 and raise the temperature, turn on the spa jets and mix in some bubbly air.  Turn on the Spa Zone music, the RGB lights and relax!
Requirements
  • myServer
  • Autelis controller installed and connected to the pool controller
  • Pool controller (Jandy / Pentair) installed, configured and running
  • Autlis myServer driver
  • Pool / Spa Family license for myServer (purchase below link)
Price $49.99
How to Install Autelis driver on myServer5
  • Purchase Pool / Spa Family for myServer
  • Configure your Autelis controller on it's embedded web page.
  • Shutdown myServer5
  • Run myInstaller Installation on your myServer PC
  • If you are connected to the Internet, you should see the Autelis driver application listed in the Pool  / Spa category. Select and download it.
  • After the App is downloaded, click to install it.
  • Restart myServer
Setting up the Autelis driver
  • Click on Device Driver
  • Click on Autelis driver
Configuring Autelis Driver
  • Double click on the GMusic app in the Server Apps window.
  • Click on the Radios tab
  • Add your Google Play Music login and password. Your choices will be saved when you close the App.  The drop down should display your unique ID - select it.  This is the ID of the device you installed the Play app on while setting up your Play account
  • Configure your next Radio (optional) with either your Google Play Music credentials or another (to use their playlist favorites - note: you can't use one ID concurrently on more than one radio).
  • Choose if that Radio is using a local PC sound card output or as a Remote device using myAgent, if it is a DLNA renderer or if you are going to stream to the myUI application on your Android device (Webclient).  Type the network name of the device you will be using.
  • Close the Play Music App
Using the Pool / Spa control:
  • Go to your browser, go to your Home page on myUI.Tablet web app and click on the Zone selection on the bottom left.
  • Click the Home page Menu link (top left)
  • Click on Pool / Spa Control.
  • Click the Browser button
  • Click the Home icon
  • Enjoy the your Pool / Spa!
Let's configure Pandora next so you can listen to music as you soak.  Similar to GMusic so it will be easy!  Click HERE
Autelis driver supported commands
Here
Autelis driver supported variables
Here
