Lutron Homeworks Driver Installation
Lutron Homeworks Lighting Driver is Allonis' application that provides a 2 way real time integration with a Homeworks lighting controller within your myServer user interface.
System Requirements
  • myServer
  • Lighting Family App
  • Homeworks programming file
  • Working Homeworks controlled lighting system on the same network as myServer
1) Install the latest version of myServer from myInstaller.
2) Install the latest version of the Homeworks driver and the Lighting Family.
3) Program the Homeworks controller.
4) Update the Homeworks Driver with your Homeworks controller's IP address.
5) Restart myServer.
6) In the Lighting Family, select Homeworks from the import sources and browse to your completed programming file that the Homeworks controller was loaded with.
7) You should see all of your Homeworks lighting loads having been created in the Lighting Family.
Usage
1) Open the Lighting web page on your server.
2) You should see your Homeworks defined Areas. Click one and you should see your Homeworks defined lighting loads. Click a control. Enjoy!
