Welcome to myServer
Thank you for your interest in Allonis's myServer automation application.
If you are looking to kick the tires - awesome! Just follow the normal installation instructions for all products. They will install and run for a 30 day free trial. There are no limitations on the software during the trial period. All of your configuration and customizations will continue to work post trial, once a permanent license has been applied to the software components.
To purchase the software related products, most are available HERE
Allonis also sells pre-configured server hardware with myServer installed and running. We also can provide full customizations of the software on a quote basis. Once the system is up and running, we can remote into the PC and install all customizations.
To being installation, start by installing myInstaller by following the instructions HERE
System Requirements
- Microsoft Windows 10, 8, Windows 7 with all the current service packs and security updates. (32 or 64 bit versions. 64 bit recommended). Windows 2008 Server OS or newer is supported. XP cannot be used. Vista should not be used.
- .NET windows update installed prior to myServer
- Modern dual-core processor or better
- 2GB main memory. (4GB or more recommended)
- 100GB free disk space
- optional: login account for Allonis's Subscription Manager
Thanx again for your interest in myServer. Please create a forum account and let us know how it's going!
