RTI ADx line of audio matrix support multiple stereo outputs of low level matrix routing.
Connect the RTI to your audio sources.
Connect the RTI to your audio amplifiers
Connect the RTI to your "control" ethernet network
Determine the IP address by looking at your Router's DHCP reservation
Type that IP address into a browser.
The password is for RTI dealers only (like Allonis).  Default is "rti".
Allonis will configure the matrix remotely and integrate it into the myServer 6 control system.
Provide Allonis with the Static IP address that the ADx should be set to that never changes (even on reboot) and doesn't conflict with DHCP address ranges or other devices on the network.  This IP address must be submitted via Allonis's configuration spreadsheet.
