Here is where having an automation system gets interesting...
Doorbell Notifications
Lets say you have a Z-Wave doorbell. And, you have added support for that in myServer using the myZWave controller. The doorbell is added to the Lighting Family automatically (as device lighting_201 - example) once the controller's device list is read in (in myZWave Driver). You have configured the myZWave controller to send to myServer a status update message whenever the doorbell is pushed. With that message, myServer can add next level value.
What if we want to:
- Get an SMS message to my phone ("David") that someone is at the front door
- Popup a message on all myServer clients (browser and myUI)
- Speak through the whole house audio system that "Someone is at the door"
Here's how:
- Click in myServer the Automation rules button
- Click the + button to add a new rule
- The "Rule Editor" will open. Click "When" button
- To the right of Select Variable, click the Refresh button (two circular arrows) to populate the variable names. This might take a few seconds depending on how many variables your system is tracking.
- Once the list populates scroll down to: "lighting_201_status" and click on it (as example)
- Select a Set Condition from the drop down list: "changes value"
- Click the Set button.
- Click the Then button
- Copy: If|IsEqual##{{lighting_201_status}}##on##Macro|WebCmd|All~Toast|Info~Door Bell~Someone is at the door~5000!WebCmd|All~Speak|Someone is at the door!SendSMS|David~Someone is at the front door##
- Paste that example macro into the myServer Command field. You will note that "David" is configured in myServer User's list and his phone number is setup.
- Click the Save button.
- Click the Close button.
You have just created a doorbell sequence of events! You'll never miss someone at the door again!
