Allonis has built multiple user interface samples and premium available templates that can be used as a model for your system's user interfaces.
You can use them as is or use them as a model to customize.  All Allonis templates are licensed and count towards your myServer Device License account.  If you aren't using a template, remove it from the wwwroot directory (put them in wwwroot/backups).
The Templates are commonly available for tablet (most commonly for 4:3 aspect ratio iPad), SmartPhone (portrait) and the SmartRemote (portrait, and small).  Often the Template are as a series that look similar and provide similar function.  myServer license includes the "Moonlight" set of templates.  The SmartRemote templates include hard button control configurations specific to each webpage.
The "SportsBar" templates are a premium template set.
"Sheer" was an older series of templates that haven't been updated for myServer latest command structure and features.
This document speaks to techniques that are used in the Moonlight templates.  The techniques are organized by Family structure.
When the Moonlight templates are installed from myServer's Software Updater,  the Default is what works "out of the box".
AV Family
XYZ
Climate Family
XYZ
Control Family
XYZ
Energy Family
XYZ
Lighting Family
Default is a myDesigner "endless list widget" that displays all enabled lighting devices by Room and then by lighting type.
The "lighting-list" is the overlay that the lighting.html webpage loads
For custom systems, you can build your own floorplan (like in photoshop) with each room as a seperate graphical object.  When that "room" is clicked, a dynamic list of lighting devices in that room are presented.  This is the "lighting-floorplan" overlay can be configured in myDesigner to loaded from the lighting.html overlays.
The floorplan view demonstrates the "Pan" capability of myServer to slide the overlay around the screen when the user touch and moves the user interface on the device.
Security Family
XYZ
Video Family
XYZ
