I was bored and decided to play with IP control for my ATV again. I setup a system variable (ATVcontrol) and set it to IR or IP. Depending on the variable it loads a scene for either the IP or IR control. I then modified it so the logic was in the button. Each button calls a macro, the macro has an ISequal statement that does a simple If, Then, Else. If ATVcontrol = IR run the IR command, if not IR, run the IP command.
I then added a button to the ATV scene that toggles the ATVcontrol variable and displays the current "control". I like using IP control, but with the ATV I found previously that it would break when the ATV was updated. With this setup, if that happens, I can simply press a button and switch it over to IR.
Is this needed...NOPE, it's just fun to play around with the system and have it do things like this.
