I recently had to start from the beginning and set up my SmartRemote again. it was pretty straight forward and I was able to avoid a lot of mistakes I made first time round but I'm struggling with volume control & power control. I have a Sony TV, Sky Q (UK satellite box) ATV, Shield & Kodi CoreELEC. The Sony TV is the device I'm trying to get to control Volume. Kodi CoreELEC just worked as it should as soon as it was installed as does the Sony TV driver. All the others are installed via drivers apart from Sky which is connected via an IP2IR
So in a nutshell when I press volume up or down nothing happens except for the Kodi CoreELEC. and the Sony TV - below is an extract from my log
What am I doing wrong, any ideas?
09/12/2025 12:45:33.45 · DEBUG · Server.doCommand - AV|{{active_cabletv_{{clientname}}}}~Volume~Up from sr209/12/2025 12:45:33.45 · DEBUG · Server.doCommand - AV|64~Volume~Up09/12/2025 12:45:33.45 · DEBUG · CableTV.doCommand - Cmd=[64~Volume~Up] Client=[sr2]09/12/2025 12:45:33.45 · DEBUG · Server.doCommand - Control|iTachIP2IR IR 3~SendIR~Q~Volume Up from09/12/2025 12:45:33.45 · DEBUG · GenericIR.doCommand - Cmd=[iTachIP2IR IR 3~SendIR~Q~Volume Up] Client=[Internal]09/12/2025 12:45:33.45 · DEBUG · GenericIR.TX >>> - iTachIP2IR:sendir,1:3,1,36000,1,1,96,32,16,16,16,16,16,32,16,32,32,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,32,32,16,16,16,16,16,16,16,16,16,16,32,16,16,32,32,32,16,16,16,16,16,16,32,32,16,16,16,16,16,16,16,360009/12/2025 12:45:33.45 · DEBUG · GenericIR.RX - iTachIP2IR(85) [completeir,1:3,1]
