Database backup
retate's Avatar Topic Author
Database backup
#493
The myServer Command Syntax documentation has the following information:
"To tell myServer to backup database:
curl http://127.0.0.1/api/docommand?command=backupdatabase"
I have the following questions:
- Is there any automated way to backup the database?
- Where are the backups stored?
- Can multiple backups be stored?
I would like to see documentation on how to backup the myServer environment so that a recovery can be performed in the case of a hardware failure.
Re: Database backup
#497
Quickly, there is a command to backup the database.  That command can be run as a Scheduled Task.  Saves to the data directory.
A full backup includes your custom templates in the wwwroot directory.
There is also a work in progress for a premium feature for myServer primary to fail over automatically to a Secondary myServer controller for mission critical installations.  You will see the beginnings of that on the Data Mirroring page in Dashboard Configuration tab.
CrabbyPatties's Avatar
Re: Database backup
2 years 5 months ago
#2326
Can I second this (I've seen the reply also thanks).
I would like to be able to set a scheduled task to automatically back up both the myServer database and all myDesigner projects) to a network location so that I can easily restore in the case of data loss.
Re: Database backup
#2329
allonis.com/support/documentation?view=category&id=414
You can create and automation event to schedule the backup via a macro that you write that runs at a given time.
Time to create page: 0.319 seconds
