I know when I was trying to use HA for the JVC projector it wasn't working, then you fixed the myServer JVC driver to work with passwords so I removed that device from HA. I just went and added it back into HA to show you what wasn't working but I can't get myServer6 to see the new device in HA. Is there some way to force a refresh?All those entity commands are in he existing HAGateway driver. To use those commands the device must be a member of the AV family and you need to send AV style commands to the device AV|<did>~Power~On Off Toggle
If you send these command to an AV device do they work?
As for Delete and Lean (Learn?). I cannot find a good reference to them on the HA docs. How do they get used?
