Home Assistant driver installed and configured but no devices found
glc650's Avatar Topic Author
#606
I was able to discover and add my Home Assistant controller and set the serial to the long-lived token I created but no devices are discovered.
Last edit: 2 years 7 months ago by glc650.
Re: Home Assistant driver installed and configured but no devices found
#607
#608
Can you ping the HomeAssistant server from myServer controller and visa versa? ie: are they on the same network?
what operating system is HA on?  A second Raspberry PI?  Is HA updated to latest OS and app?
#616
Turn on verbose logging in the driver and watch the live event log. you should see the driver trying to connect. if it fails you should see an entry for that too.
#628
Yes.
HA OS.
Odroid N2+.
Yes.
Ok I turned it on but I have no idea where to access the log from.
#629
One thing I just thought of.  I have the DuckDNS with Let's Encrypt addon installed on my HA.  That requires HTTS access.  I'm guessing myServer only connnects to HA via HTTP?
