Hardware Recommendation
1 year 5 months ago
#4169
We are building a new home and I am designing a basement home theater.  I would like to have remote control of the lighting and the window shade.
Rather than buying something and then asking if a driver exists, I thought I would just ask:
What do I need to buy hardware-wise to make it easy to control everything with MyServer?
Re: Hardware Recommendation
1 year 5 months ago
#4170
In my theater I use Lutron Caseta switches with the Lutron Pro hub. I don't use any motorized shades (yet) but I believe the Lutron driver supports them.
bitzerjd's Avatar
1 year 5 months ago
#4171
You could also use Home Assistant as the middleman.  For example, I kick off scripts (or scenes) that do things like setting lights (multiple, throughout the house, and outside (the deck) to a preset.  I can also easily control the wide variety of crap I have.  The nice thing about this approach is that if Allonis doesn't have the driver, you can still control it.  The downside is that it's another system that needs to be maintained.
1 year 5 months ago
#4172
I too would go with Lutron.
1 year 5 months ago
#4173
I did a quick web search based on your suggestion.  They offer "Serena Shades" that are compatible.  Not sure how the prices compare with other shade manufacturers, but a quick configuration of a honeycomb blackout shade in the size I need is almost $900.
1 year 5 months ago
#4174
Yes, Lutron shades are not inexpensive.
But, you can use Lutron lighting switches and XYZ shades.
You can use inexpensive "Z-Wave" shades.
Let myServer control both.
You can create an Automation rule that "If the Lutron switch is turned ON, then raise the Z-Wave blind 50%"
Scenes like that (if applicable but probably not).
Time to create page: 0.327 seconds
