The PIM seems to be under USB0 so I tried adding it using this command:
UPB|AddSerialPIM~Name~/dev/ttyUSB0~4800,8,n,1~0~Equipment
It seems to be transmitting UPB with no error messages in the MyServer log. On another Windows maching with Upstart I can log the transmissions from MyServer. BUT, devices aren't responding to the commands. I logged a command sent from MyServer then a command from Upstart. There seems to be a difference in the logged event. Not sure if this means anything or not but I screen captured it. Update: I can't attach the screen capture.
The command by Upstart logged something in the last column under "Name." Myserver commands had nothing in that column.
