Windows Update - Designer now will not work
#3716
FYI
I just applied the recent Microsoft Update (Windows 11, version 24H2) and myDesigner will not connect to the myServer.  My un-updated PC works fine and the configuration settings are identical.
I'm updating one of my other PC's to see if I have the same issue.
I will update this post shortly...
Update - Same behavior on my other two PC's (one auto-updated last night)
Last edit: 1 year 9 months ago by bitzerjd.
Chrisan's Avatar
Re: Windows Update - Designer now will not work
1 year 9 months ago
#3717
I'm not yet on V6 but I have fairly extensive experience on V5. Have you tried re-installing the Designer?
1 year 9 months ago
#3718
I don't think that will help.  After the update, you cannot map a drive to the myServer and if you had one mapped, it will not connect.  This is a Microsoft issue... I will try the reinstall because I'm dead in the water.
retate's Avatar
1 year 9 months ago
#3719
I have been on Windows 11, 24H2 for a few weeks. All components (Windows 11, myServer, & myDesigner) are current on updates. I just confirmed that myDesigner is connecting to myServer. The last time I had a problem with connectivity between myServer & myDesigner I believe an uninstall and reinstall of myDesigner resolved the issue. This was a while ago, so I don't remember if it happened at the time of my 24H2 upgrade.
Chrisan's Avatar
1 year 9 months ago
#3720
Ah, you can't map to it. Re-install MyServer then. It sets up sharing when you install it. Hopefully it will allow you to reconnect. Had that happen to me in V5 anyway.
1 year 9 months ago
#3721
Uninstalled it, rebooted, Reinstalled it. No difference.
Again, the app worked on a PC (before I installed the update, minutes before) and stopped working on all three PC's after the update.
There are a lot of complaints about the update breaking applications in the Microsoft Forums... Unfortunately I don't have a fix yet.
Time to create page: 0.267 seconds
