Toast Error even though it works
louielc1's Avatar Topic Author
#3391
When using the channel Guide, i see all the channels and shows correctly. When i select a channel it changes my cable box to the right channel. But i have a toast popup every time saying it dosent work. How do i get rid of the toast error Channel Not Available? It works fine but is annoying to have a popup that i cant seem to get rid of. I dont see anyway to change the Lineup string its even looking for?
06/10/2024 11:55:13.55 · ERROR · myTV.ChannelAvailable - Error in ChannelAvailable - The input string 'Lineup' was not in a correct format.
06/10/2024 11:55:13.55 · DEBUG · Server.doCommand - WebCmd|all~Toast|warning~Channel Not Available~Channel 502 is not available. Please try another channel.~5000 from
06/10/2024 11:55:13.55 · DEBUG · Server.WebCmd - all~Toast|warning~Channel Not Available~Channel 502 is not available. Please try another channel.~5000
Last edit: 1 year 11 months ago by louielc1.
Re: Toast Error even though it works
#3398
How are you entering the channel? via smartremote hard button keypads? or via the TVGuide on screen? If via TVGuide, then you might have the wrong listing for your actual provider. You are sending the wrong channel numbers for what your receiver processes for your lineup.  You might be sending IR faster than what your IR / cable box can handle.  Test by manually entering in the same channel numbers.  You might need to add some Pause to the command.
#3409
VIA the TV guide on the screen. It has the correct channel shown in the guide and the correct show that is on. It also works. I press the channel, it selects the correct info and send the channel. It still pops up its not available anyway. I doubt its a Lineup issue, since its giving me the correct info and changing my cable box to the correct channel.
Time to create page: 0.399 seconds
