My server 6 SMb file browsing
Sat32's Avatar Topic Author
#3215
I just installed myserer 6 and transfered the licience to new hardware pi5 with nvme drive. After a few hiccups I got everything up and running
But I'm having a issue browsing the shares on the server and if I hit the locate image button in mydesigner "which I assume opens a explorer window" the program crashes.
Here's what I've tried and or done
-set static ip using network manager on myserver6 desktop, manual needs updating pi OS debian bookworm no longer uses dhcp.conf by default.
-deleted credentials from windows and added them back
-disable my antivirus software on windows pc  "eset"
-reinstalled network adapter drivers on windows pc
-looked at smb.conf on my server for any errors that might stand out "not a linux expert by any mean though"
-installed wsdd on myserver "i could see myserver in explorer but still couldn't browse files or folders.
-ran virus/malware scans on my computer
-ran smbstatus on myserver to make sure it was running. "it was and my pc's ip address was connected to it"
-uninstalled and reinstalled mydesigner
I have two other linux based servers, OpenMediaVault 7 running on X86 and Home Assistant running on a pi4.
With both on these I can open a explorer window and get to a shared folder with
\\ip address\share
I even deleted My Home Assistant windows credentials to check if my PC would prompt for username /password and it did.
I've pretty much ruled out an issue with my computer.
Mydesgner works it shows all the projects and I can map a drive to myserver using the "use other credentials check box"
but the funny thing is mydesigner uses the same path \\ip address\myserver that windows explorer can't access
I know I saw other posts with this or simular issues
Anybody have a solution or a easy workaround
Last edit: 2 years 1 week ago by Sat32.
Re: My server 6 SMb file browsing
2 years 1 week ago
#3216
It sounds like something is not quite right with the Samba setup.  When I setup MyServer in a VM, I followed these instructions for Samba:
ubuntu.com/tutorials/install-and-configure-samba#1-overview
Perhaps this might help.
2 years 1 week ago
#3217
I was having similar problems connecting MyDesigner to the MyServer. What worked for me was to take MyDesigner out of the picture, and attempted to establish a permanent file share connection from my windows system using Windows FiIe Explorer.  Once I had established that permanent file share connection, MyDesigner would connect with no problem. As I recall I had to try several different user name/passwords when connecting with File Explorer before I found the user name/password combination that worked.
2 years 6 days ago
#3219
Here is the smb.conf file that myserver is using if anyone can spot something that looks off I'd appreaciate it
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Some options that are often worth tuning have been included as
# commented-out examples in this file.
# - When such options are commented with ";", the proposed setting
# differs from the default Samba behaviour
# - When commented with "#", the proposed setting is the default
# behaviour of Samba but the option is considered important
# enough to be mentioned here
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not made any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
force user = allonis
force group = allonis
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
workgroup = WORKGROUP
#### Networking ####
# The specific set of interfaces / networks to bind to
# This can be either the interface name or an IP address/netmask;
# interface names are normally preferred
; interfaces = 127.0.0.0/8, eth0
# Only bind to the named interfaces and/or networks; you must use the
# 'interfaces' option above to use this.
# It is recommended that you enable this feature if your Samba machine is
# not protected by a firewall or is a firewall itself. However, this
# option cannot handle dynamic or non-broadcast interfaces correctly.
; bind interfaces only = yes
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
log file = /var/log/samba/log.%m
# Cap the size of the individual log files (in KiB).
max log size = 1000
# We want Samba to only log to /var/log/samba/log.{smbd,nmbd}.
# Append syslog@1 if you want important messages to be sent to syslog too.
logging = file
# Do something sensible when Samba crashes: mail the admin a backtrace
panic action = /usr/share/samba/panic-action %d
####### Authentication #######
# Server role. Defines in which mode Samba will operate. Possible
# values are "standalone server", "member server", "classic primary
# domain controller", "classic backup domain controller", "active
# directory domain controller".
# Most people will want "standalone server" or "member server".
# Running as "active directory domain controller" will require first
# running "samba-tool domain provision" to wipe databases and create a
# new domain.
server role = standalone server
obey pam restrictions = yes
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
unix password sync = yes
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for
# sending the correct chat script for the passwd program in Debian Sarge).
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
pam password change = yes
# This option controls how unsuccessful authentication attempts are mapped
# to anonymous connections
map to guest = bad user
########## Domains ###########
# The following settings only takes effect if 'server role = classic
# primary domain controller', 'server role = classic backup domain controller'
# or 'domain logons' is set
# It specifies the location of the user's
# profile directory from the client point of view) The following
# required a [profiles] share to be setup on the samba server (see
# below)
; logon path = \\%N\profiles\%U
# Another common choice is storing the profile in the user's home directory
# (this is Samba's default)
# logon path = \\%N\%U\profile
# The following setting only takes effect if 'domain logons' is set
# It specifies the location of a user's home directory (from the client
# point of view)
; logon drive = H:
# logon home = \\%N\%U
# It specifies the script to run during logon. The script must be stored
# in the [netlogon] share
# NOTE: Must be store in 'DOS' file format convention
; logon script = logon.cmd
# This allows Unix users to be created on the domain controller via the SAMR
# RPC pipe. The example command creates a user account with a disabled Unix
# password; please adapt to your needs
; add user script = /usr/sbin/useradd --create-home %u
# This allows machine accounts to be created on the domain controller via the
# SAMR RPC pipe.
# The following assumes a "machines" group exists on the system
; add machine script = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u
# This allows Unix groups to be created on the domain controller via the SAMR
# RPC pipe.
; add group script = /usr/sbin/addgroup --force-badname %g
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
; include = /home/samba/etc/smb.conf.%m
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
; idmap config * : backend = tdb
; idmap config * : range = 3000-7999
; idmap config YOURDOMAINHERE : backend = tdb
; idmap config YOURDOMAINHERE : range = 100000-999999
; template shell = /bin/bash
# Setup usershare options to enable non-root users to share folders
# with the net usershare command.
# Maximum number of usershare. 0 means that usershare is disabled.
# usershare max shares = 100
# Allow users who've been granted usershare privileges to create
# public shares, not just authenticated ones
usershare allow guests = yes
#======================= Share Definitions =======================
[homes]
comment = Home Directories
browseable = no
# By default, the home directories are exported read-only. Change the
# next parameter to 'no' if you want to be able to write to them.
read only = yes
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
create mask = 0775
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
directory mask = 0775
# By default, \\server\username shares can be connected to by anyone
# with access to the samba server.
# The following parameter makes sure that only "username" can connect
# to \\server\username
# This might need tweaking when using external authentication schemes
valid users = %S
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
; comment = Network Logon Service
; path = /home/samba/netlogon
; guest ok = yes
; read only = yes
# Un-comment the following and create the profiles directory to store
# users profiles (see the "logon path" option above)
# The path below should be writable by all users so that their
# profile directory may be created the first time they log on
;[profiles]
; comment = Users profiles
; path = /home/samba/profiles
; guest ok = no
; browseable = no
; create mask = 0600
; directory mask = 0700
[printers]
comment = All Printers
browseable = no
path = /var/tmp
printable = yes
guest ok = no
read only = yes
create mask = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
browseable = yes
read only = yes
guest ok = no
# Uncomment to allow remote administration of Windows print drivers.
# You may need to replace 'lpadmin' with the name of the group your
# admin users are members of.
# Please note that you also need to set appropriate Unix permissions
# to the drivers directory for these users to have write rights in it
; write list = root, @lpadmin
[myServer]
path = /home/allonis/applications/myServer
Comment = myServer shared folder
Browseable = yes
Writeable = yes
only guest = no
create mask = 0777
directory mask = 0777
Public = yes
Guest ok = yes
[myMedia]
path = /home/allonis/applications/media
Comment = Shared media folder
Browseable = yes
Writeable = yes
only guest = no
create mask = 0777
Public = yes
Guest ok = yes
2 years 6 days ago - 2 years 6 days ago
#3220
I don't see a problem with the Samba config file.
Samba keeps its own password file.  Have you setup a Samba user?
sudo smbpasswd -a allonis
Adds the allonis user to Samba, and prompts you to set the password.
Last edit: 2 years 6 days ago by cjisble.
2 years 6 days ago
#3221
Tried setting password just before you mentioned it
still doesn't work
yet I can map a drive to the share
this is so frustrating at this point i'm just throwing stuff at the problem
