V6 is is up and running and I have been having fun playing with it. I can't seem to get weather variables to show up in the System Server Variables area. I have the latest weather app installed and followed the procedure in the tutorial (copied below). I selected Zip then City and tried to force a weather update a couple times. No dice. Maybe because I'm still on a "trial version?" I hit activate a couple days ago but it is not yet activated.
Thx, ChrisClick the dropdown to the right of the Select City to Add field that appeared.Select your city from the list and click Submit.Your city should have been added to the list of your cities. The first time you do this it will be enabled by default. You can edit that city to add Marine data for large body of water facing cities.The units of measure can be set to Metric using the Command BuilderYou can click the Update function in Command Builder to force an update. Typically the weather data will be ongoing downloaded a few times per day as long as the myServer controller has access to the Internet.
