Directv Osprey Box
Re: Directv Osprey Box
8 months 2 weeks ago
#4750
cool...Please post on what is working vs. not working and it's responsiveness.
Part of the headache for Allonis to test is we don't always have subscribed services (like you do) so our testing is aggravated by that.
#4753
I made a "Frankenstein" scene combining IR and AndroidTV commands. IR doesn't have a pause-play command (I had a macro that would set a variable and then run Play or Pause depending on the variable), AndroidTV does.. it works great.
For single commands (Guide, Info, etc) the speed seems to be the same. I need to do more testing with things like cursor movements.
#4754
So far, your findings are what I have seen.
Note: I use the macros that issue multi Page up / Down associated with the Ch Up / Down buttons in the Roku page. This has been an excellent user experience to navigate TV Guides. One whole page of readable Guide to scan What's Playing. The IR might be faster in these navigations, but you can't read that speed anyway.
PhoenixF15E's Avatar
#4756
I set up the Android TV integration again to check it out.  As mentioned above, cursor, FF/REW, and pause are a bit slow.
I did notice an oddity with the driver.  I have my OK button on my SmartRemote set up as SendKey~Enter in MyDesigner.  However, when I hit that button, MyServer was sending out a command to open an app.  Most of the time it' was Plex, other times it was Paramount.  I also tried Dpad~Center and it did the same thing.
I just tried it again and now it seems to be working.  There have been a lot of MyServer updates recently, not sure if one of them fixed the issue, but all seems well for the time being.
