Venstar - Quick Sales Question
Re: Venstar - Quick Sales Question
1 year 8 months ago
#4030
Do I understand you can use the climate simulator driver for real, adding in some kind of temperature sensor and a separate device to control? All I can find is allonis.com/support/documentation?view=category&id=294 which doesn't help much.
1 year 8 months ago
#4031
yes, it is intended to do that.
We have used it for simulations of hardware based thermostats for a long time. But there is no reason it can't also be used for real implementations. I have a few projects here for that, but haven't had the time to put that together. Feel from to try and post your success.
Chrisan's Avatar Topic Author
1 year 8 months ago
#4032
I may check this out. Does it simulate a programmable thermostat? If so, I may have a couple projects for that.
Thx, Chris
1 year 8 months ago
#4033
Programmable via Scheduled Tasks in myServer
Will Riker's Avatar
1 year 7 months ago
#4037
Is there a way to manually add the thermostat?  Discovery isn't working for me.  This thermostat worked fine with MyServer V5
1 year 7 months ago
#4038
Hi Will, what thermostat are you using? A Venstar? Discovery should work. Is APK turned on on the thermostat? Have you been able to Ping it from myServer 6?
The Venstar driver is Beta. We know there are some variable naming inconsistencies that keep the out of the box UI's from populating correctly. There isn't a manual entry today. I would suggest need to figure out why Discovery isn't working. Let us know your TV ID / password (if you changed that) via a PM so we can log in and see why Discovery isn't working. But make sure the Thermostat is APK On and on the same subnet as myServer 6 is.
