Friendly reminder - don't power cycle the myServer controller!
cjr181's Avatar
Re: Friendly reminder - don't power cycle the myServer controller!
1 year 5 months ago
#4262
I was able to move the switch to "disable" for the "always on" setting on the shelf mount box.  When I execute "Power Off Host" the OS shuts down but I still have to manually power off the controller box with the power button (ie, change it from blue to red).  I need to investigate if there is a way for the box to automatically go Off, like occurs when shutting down a typical windows machine.
Also, I wanted to confirm that this is still the relevant curl command (which I can relay from the windows machine to controller via ethernet):
curl http://127.0.0.1/api/docommand?command=poweroff
Source:  allonis.com/support/documentation?view=category&id=247
Thank you
Time to create page: 0.316 seconds
