Re: JVC Projector Driver
#2112
Hi Dave, along with my questions above I was wondering if a "test" command could be added to the JVC driver so that I could send arbitrary commands. Thanks.
Mark Guebert's Avatar
2 years 5 months ago
#2375
Hello,
I have a RS6710 projector and using the driver I can connect to the projector and control power state, lamp mode, and lens memory. However the only choices for lens memory are 1 - 3, I have 4 lens memories i use on a regular basis for CIH projection. I tried modifying the command sent to the projector by changing the number, but that still only works for 1 - 3.
No errors show in the logs, it shows the command sent but no response from the projector.
#2488
Any progress on this request?
#2498
I just modified the driver to support a 4th lens memory. Note: the protocol documents I have do not have any references to any lens memory greater than three. So I made a logical guess at what the command would be based on what 1..3 look like. Let me know if it works.
The following user(s) said Thank You: graydon@gdsamps.com, Mark Guebert
#2522
Lens Memory 4 now works using a direct command, still in the gui driver command area it only shows 1 through 3. Modify the command to 4 works though.
I am not sure about other JVC models but mine has a total of 10 lens memory slots. I tried 5 and higher also but they don't work.
#2524
I fixed the command builder issue and bumped the lens count to 9.
