Power On (Wake on LAN)
Re: Power On (Wake on LAN)
#1278
I'm going to have to come back to this later.  I have the Turn on by WIFI on, turned off Quick Start+, Turned on Live Plus (Found that on a Control4 forum).  I've shut power off to the TV for several minutes to make sure it restarts (though I don't recall seeing the webos logo so that's suspicious).
In the meantime, I added the IR model to the GenericIR driver and put the command to send Power On via IR in my poweron.livingroom macro which is working for now.
#1455
Getting back to this, to keep it short, I had no luck getting WOL to work with my TV, despite having the "Wake on WiFi" setting turned on.  Finally today I plugged it into ethernet (wired) and updated the IP/MAC addresses and WOL works just fine.  Guess this means I'll run another ethernet cable to this room.
#1456
By chance is your Wifi network on a different subnet? WOL won't traverse subnets.
#1458
Nope, it's all the same.  it was 192.168.0.63 on ethernet and 192.168.0.158 on wifi.
#1461
well, that points to a setting on the TV...since WOL is same and it's working via ethernet so myServer and the network are doing fine.
#1462
Yeah, I'm really not sure. Like I said, I turned on the "Wake on WiFi" setting and disabled all the power saving settings I could find, but no luck. I did notice that the TV drops from the UniFi client list when I power it off.
