MyDesigner6 window frames misaligned
Re: MyDesigner6 window frames misaligned
#3006
That's not a bug. that's a configuration requirement.
It's in the documentation.
allonis.com/support/documentation?view=category&id=191
It's really important to follow the documentation.
You will be in the weeds if not.
This is a highly customizable / configurable professional system.  You can't wing it.
Last edit: 2 years 2 months ago by David Li.
#3007
Yes, as it turned out, it was a permission problem. The network share requires a username/password to accomplish the connection. Interesting as I cannot find anywhere inside of the Designer to enter credentials.
Is there a maintained list of bugs for Allonis software? Reducing to 100% makes everything on the screen very small and hard to read. Not an urgent problem, but Allonis might want to look into this as the smallness is hard to read, especially for older people.
IIRC You can reduce the resolution your monitor is outputting so long as you keep scaling at 100%. This will make things appear larger.
Your credentials aren't entered in myDesigner. When you go to access the network share in File Explorer if it asks you for credential I believe the password/username is allonis/allonis. Alternatively you should be able to create an entry for this in the Credentials Manager.
Mr_Orange's Avatar
Banned Banned
10 months 3 weeks ago - 10 months 3 weeks ago
#4579
I managed to work this out, but maybe you need to consolidate or check all your documentation. This page: allonis.com/support/documentation?view=a...rver-configuration-2 , linked to from the hardware set up page for a Pi, makes no mention of the authentication issue and how to solve it.
Last edit: 10 months 3 weeks ago by Mr_Orange.
#4580
That's because it's here under myDesigner
Mr_Orange's Avatar
Banned Banned
#4581
Yes, but you have another page with conflicting, well a lack of, information.
Starting here: allonis.com/support/documentation?view=category&id=166 , and following the subsequent links on the page, a new user ends up on the page I previously linked to and is left hanging.
Time to create page: 0.595 seconds
