Error Message Installing V6
Chrisan's Avatar Topic Author
Re: Error Message Installing V6
1 year 7 months ago
#4059
Sounds good, thanks Will.
1 year 7 months ago
#4060
Thanx Will,
The most important tidbit for all is: Read and follow the Allonis documentation!
Secret to success and keeping your hair in your head.
If something is confusing with the documentation - let us know so we can fix it.
Thanx!
David
1 year 7 months ago
#4062
Thanks David,
How about this one.   This is where I got stuck.   And I can't remember the last time I installed a Windows program that did not use a Setup.exe file or similar.myServer 6 Windows Download Getting Started  (starting at step 5)
5) Move the file to your target Windows 10 or 11 PC you would like to install to.
6)  You can optionally plug the Primary HDMI port into a PC monitor using a Micro HDMI cable adapter.  You can also optionally plug a wireless keyboard / mouse into the USB2.0 port (not a blue one).Shouldn't there be something between Steps 5 and 6?   The file you download is a Zip file.   I made the apparently false assumption you would unzip it and run some sort of Install.exe or Setup.exe file.
Thx,  Chris
1 year 7 months ago
#4063
What document are you referencing? Please provide a link.
Yes, there should be a full Windows installer...doesn't exist right now.
Keep in mind, there are very few people using Windows.
1 year 7 months ago
#4064
1 year 7 months ago
#4065
Ah ok, that part of the doc was certainly never finished...I updated it a bit from top of mind, but it certainly needs more and will change again once there is a myServer_setup.exe installer.
