My server 6 SMb file browsing
Re: My server 6 SMb file browsing
2 years 3 weeks ago
#3222
If you can map a drive to the share, try changing the MyDesigner settings to point to the mapped drive, rather than supplying a share path.
Sat32's Avatar Topic Author
2 years 3 weeks ago
#3223
That worked
last time i tried to use a mapped drive in mydesigner it gave a error.
2 years 3 weeks ago
#3233
Sat32, did you install the Master Image on the NVME or are you attempting to do a manual base installation?
High recommendation is to use the Master Image.
2 years 3 weeks ago
#3238
I used the master image had to install it on a USB stick then after getting myServer booted to the desktop I used the sd card copier to copy OS to nvme. Then I could remove USB and boot directly from nvme
I did try disabling PCi gen3 support since it's not certified
2 years 3 weeks ago
#3239
by the way I have a I little pen icon on the Reporting drop down menu in the dashboard, What does that indicate??
2 years 3 weeks ago
#3242
That pen icon shows where the new Event Log spacer lives to make it easier to track commands you then process in the log.
