#1336
Hi Fattykidd,
Could you please share your macros for the HTP-1 your projector and Dirac functionality?
Thx.
The Dirac button is just a toggle for on/off. I got the ir command through the ir database in myServer.
I created the htp in the new avrir driver. It created the htp macro and source.
I then had to import the htp ir command set through the database and link it to the device created in avrir with one of the ip2ir ports.
kirky27's Avatar
#1662
I have a question if you don't mind:
How do you add a macro for a AVR that has no ready made allonis driver and then switch it to the appropriate input/output?
Thanks.
#1663
What are you using for control? Infrared?
If so, then you use the command structure outlined in the IRDatabase for the device you are controlling and via the port you are using (if IP2IR).
Or if you are using Harmony Hub to control, via the Harmony Device commands. ie: "AV|deviceID~Down"
kirky27's Avatar
#1666
Yes I am using the IP2IR to control the device.
#1668
That should give you how to setup IR commands via the IP2IR
the Macro syntax is same for IP devices. Just swap the corresponding IR command for your system.
kirky27's Avatar
#1669
Thank you David.
