1 year 11 months ago
#3524
@rec head
Did your serial number populate?
Mine just populated with the mac address. I was still able to follow the steps but I can't control my atv4k via my remote either. Works fine from the command testing section of the driver though.
My two tokens look similar but are definitely different.
#3525
If you can control from the myServer command builder (in the driver) then you have the handshake correct and the issue is not in the driver but in the UI / macros / setting the ATV1 as "active" something along those lines.
#3536
So I checked the codes and I do have different codes. Only the first 100 characters were the same.
I'll look into the macro stuff when I can. From what I remember we are getting into the territory that David told me to stay away from.
Last edit: 1 year 11 months ago by rec head.
#3537
The error message advises that you did not have the authentication bits correct.
If that is still current, then please redo that from scratch.
That should clear the error. This isn't macro related. It's handshaking between myServer and the AppleTV box.
Time to create page: 0.252 seconds
